Hi all,
I scooped up one of those amazingly cheap Kolink Observatory cases a few months ago to replace my older PC case, I like to refresh its look every now and then.
Im running a custom loop which is a little undersized cooling a Nvidia 980 and a i7 5820k, but only with a single EK 240mm rad, so temps aren't the coolest, I did have another 240 rad too, but I put a hole in it with a screw
The issue is those fans that came with the case were truly awful, they have almost no static pressure at all, but the main reasons I bought the case were for the RGB and the tempered glass.
I swapped the fans to my old EK Vardar F4 120 2200RPM versions which have a SP rating of 3.16mm H2O. I do not run these at full power as im scared they will suck me into the case but im looking for some addressable RGB fans with a decent SP rating due to my undersized rad for what im trying to cool. The EK Vardar RGB's aren't addressable so you cant have the fancy effects which I like.
My motherboard was just before RGB became a thing, so I also need a dedicated controller.
Im really struggling to find anything even with a SP rating above 2.0, so thought id ask the ones in the know for some advice Im after a min of 3, but possibly 5-6 fans. Any suggestions?
Oh, also, the Kolink has almost no space between the chassis metal and the glass front plate and I have no internal space to move the fans inside the case itself due to my reservoir mount location, so adding an RGB ring onto the existing fans isn't possible.
Thanks!
Thanks!
