I can't hear mine at all, not even under load, mind, it never goes above 33%. Have to raise it to 40% for me to hear it at all.
The fan in my Sapphire 6850 is very good too. I suppose it depends on what your personal tolerances are and where you PC is located on your desk.
Just how it came out the box, Vinny, perhaps spin the fan with your finger and check that it isn't catching on the cowl.really quiet unless when gaming I mute the sound and listen for it
OTOH, if you suspect it's going to make a noise, put your headphones on and the card is silent once more
My god man, you LOOK for trouble?OTOH, if you suspect it's going to make a noise, put your headphones on and the card is silent once more
