- 8 Oct 2004
I know there is a chuck patch but isn't this supposed to be incorporated in the latest drivers. I'm currently using the 7.4 drivers with a X1950pro.
Needs to be enabled.LoadsaMoney said:Also i can't remember if you need to enable/disable the CAT A.I either as its been a while since i played it on an ATi card.
Flanno said:Just wondering if the same can be done with G80. Last time I tried to force AA in nvidia driver and use HDR in game, I ended up with no AA.
IceShock said:didnt some one make a patch so you could use AA and HDR on all cards? cant remember tbh but im sure i got it working on my 7800gtx a while back
LoadsaMoney said:Yeah its been in the drivers for yonks now, id try differnt drivers.![]()
Phat_Larry said:Seems to have done the trick, works fine with Cat 7.1, odd that it doesn't work with 7.4 though.
LoadsaMoney said:It did, ATi implemented it into their drivers from the CAT 6.11's onwards, there is no need for the chuck patch now.![]()
