- 2 Nov 2004
I can't use IE in Vista and it seems there is a problem with DHCP... anyone got any ideas on how to fix?
greenlizard0 said:Probably not the best solution that will be offered, but if you can't fix the problems you're experiencing then try another web browser e.g. Opera or Firefox.
But as I say I'm only offering a last ditch solution..![]()
Fanatic said:View status of the connection then click diagnose - then choose from get new IP or reset connection.
Virtually everytime i wake the PC from sleep i have to do this. Could be router settings of course but i forgot my password![]()
NathanE said:Does the Internet and your LAN work? If so I don't see how it can be a DHCP issue
Is IE just giving DNS errors or something?
guess i'll have to reinstall this thing.
