the z9 comes with 4 fans (more than most if not all other cases) a temp reader and a fan controller as standard. pretty smashing deal for south of 50 quid if you ask me ;p
You forgot to mention the P4/8 aux power extension lead supplied free as well.
Your spec isn't bad. I don't think you've ever used a Z9 case otherwise you would be spec'ing a modular PSU.
As the OS is out of stock anyway, I'd suggest using the developers copy of windows 8 now and choose an OS in october once Win 8 is officially released.
YOUR BASKET
1 x Sapphire HD 7850 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz & Dirt Showdown PC Games £173.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £169.99
1 x ASRock Z77 Extreme4 M Intel Z77 (Socket 1155) DDR3 Motherboard £101.99
1 x Seagate Barracuda Green 2TB SATA 6Gb/s Hard Drive - OEM (ST2000DL003) £89.99
1 x Samsung 128GB SSD 830 Desktop Series SATA 6Gb/s Solid State Drive - (MZ-7PC128B/WW) £79.99
1 x Cooler Master Silent Pro Modular 600W '80 Plus Bronze' Power Supply £65.99
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £49.99
1 x GeIL Dragon 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (GD38GB1600C11DC) £39.95
1 x Cooler Master Hyper 612S CPU Cooler (Socket LGA1366/1156/1155/775/AM3/AM2+/AM2) £32.99
1 x LG GH24NS90 24x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £836.86 (includes shipping : £12.50).
I think you might need to add a sata cable to the above build unless you have one spare.
However that is Xfire capable, Good sized SSD for the OS and games, 2TB of storage is more than plenty. I prefer the Coolermaster 612S myself over the matterhorn. Comes with a tube of paste (rather than a sachet with the matterhorn), fans are easier to attach as well. The cooler is tweaked towards being quiet, if you want better cooling performance you could consider attaching two of the LED fans from the case instead
The mobo power cables are "hard wired" all the other cables required can be connected seperately.....everything you need comes in the box
