honosuseri
On the Zalman Z9 door, the mesh holes look big, does dust get in easy as it looks like it could from the size of the mesh holes ?
Also while i'm here just a couple of quick things, that internal wi fi card you posted above doesn't get good reviews on the customer feedback tab, would it be safer to go with the dongle or a better wi fi card if they have one on here.
MEMORY: Because i'm going with a Gigabyte board that has blue in it, would these Corasair Vengeance be suitable for the Gigabyte motherboard above which i'm going to use ? Do you rate them as memory ?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-300-CS&tool=3
If you'd prefer the USB dongle fair enough, the one advantage is that you can use a USB extension so you can place the USB dongle in different places to get a better signal sometimes.How do you copy and paste a shopping basket like people have previously done on the thread where it displays it in the same form.
Ive ordered my build from OCUK and should be here tomorow.
The bluray writer will burn and read DVDs too bud. You don't need an extra optical drive. I hope the bluray was a retail unit and not OEM
I have a card reader in my Z9 too. Does prove handy from time to time and looks good sat in the bay![]()
The blu ray burner is retail, i need an extra optical drive to copy from one disc to another as i burn quite a lot of dvd's as back up.
When you can (probably best to do it before you start building, will save hassle) I'd swap the fans which come with that case for some of these, they're a lot quieter than the Zalman ones. And as for the side panel, i've got one of these and it does a blinding job.
Thanks for the pointer, with it being my first build i'll just try and get it going first then i can look into slight mods later, the fans seem an easy upgrade so i can do them at any point i guess.
These are the fans i was going to look at, someone mentioned them on another thread on here.
http://www.youtube.com/watch?v=11TIfocssvY
Operating system question.
With windows 8 not far away dop you reckon it would be better to install the windows 8 preview version as my OS for the time being like someone suggested previously then decide later if its better to go with 7 or stick with 8 ?
I presume that windows 7 will drop in price once 8 is released.
After all the help/advice i've given, I'm not sure I like being refered to as "someone" lol
This would be the one me thinks http://uk.gigabyte.com/products/product-page.aspx?pid=4144&dl=1#dl
.... A bit of sticky tape should do the trick.
