[TW]Fox;17428324 said:So gearing isn't a real factor?
I'm assuming the car has been geared correctly from the factory. As long as it's in the right ball park it's not going to make a massive difference.
1. The BHP part is peak BHP, far more important is how it delivers the power before this point.
[TW]Fox;17428486 said:Geared correctly for what? Different cars are geared from the factory for all different purposes.
Long gearing only really affects first gear acceleration. Once rolling short gearing rarely helps as you tend to be in a higher gear, at the same speed, than a 'normal' box.
Long / Tall gearing will have an effect in all of the gears.....
You completely misunderstood my post. Long gearing often means your in a lower gear than a shorter geared car. Which means the shorter geared car has no advantage.
Of cour though, the gearing needs to match the engine characteristic to some extent
BHP/Tonne is very relevant IMHO.
Obviously Aero and Gearing is going to affect the top speed, but if I was only using one number in a comparison it would definitely be the BHP/Tonne.
In a track scenario, a high BHP/Tonne car is going to accelerate faster. Might not have the best top speed (but how long is the straight anyway?). Then turns up a corner and the high BHP/Tonne car weighs less so stops a lot quicker and corners faster, then accelerates out faster.
I was passenger in Dad's Westfield at Castle Combe the week before last (it was only a public day so no timing and stupid amounts of traffic). Yes the high power cars start creeping up on the straights, but the 500BHP/Tonne Westfield just laps so much quicker than anything that was there. Still being foot flat-to-the-floor for an extra second or two coming into the corners compared with the lardy Scoobs and Evos is just hilarious!![]()
Does you Westfield really have well over 300bhp, as I suspect with a driver and passenger your vehicle weight is going to somewhat over 600kg.
. I keep telling him that perhaps if the driver was swapped with me being a few stone lighter than him....
. But Titanium Bolts and replacing everything with Carbon doesn't come cheap!This is very important point:
Imagine a 3.0 v6 engine (for arguements sake) with 200hp. This doesn't seem a huge amount but it pulls nicely all the way through the revs.
The new version of this car may have 260hp but it is rubbish at low revs and the power only really peaks at the red line.
The 260hp one to market the car as being 'faster' as the last.
as for bhp/ton.. remember that veyron vs mclaren race?
brute power goes a very long way
Torque isn't really that good an indicator. BHP/tonne is a better indicator in any way than torque is, as BHP is a product of torque and a key factor - the rate of work. 25000 Nm at 50 RPM (~175 HP) is not as useful in a road car as 200 HP at 5500 RPM (~255 Nm).BHP is a figure used to sell cars, torque is a figure used to move them according to bhp per tonne figures I should be able to beat a Camaro Z28 in a drag race, yeah lol, in a straight line drag bhp/t is pretty relevant but torque is still more important, on a track the suspension/aerodynamics/chassis/tyres/etc all play their part
