how to choose optical out from sound card?
17 Dec 2007
Easington Lane
Hi all i got managed to get a AVR with optical in so have now connected a optical cable from the out on my sound card to the in on the AVR now im stuck as to swtich between the 3.5mm jacks im currently using to the optical on the PC's control panel?
Thanks
rjd
rjd
4 Mar 2006
London
Thanks
Hi robgti
Look in Control Panel Sound and Audio Devices and or the software for your sound card/on-board sound e.g Realtek HD Sound Effect Manager.
AV Amps usually allow you to connect both analogue and digital to the same input so you can select as required.
You should be able to use either or both. For example, I use the Coaxial out from my sound card to my DAC and the analogue out to another 'Hi Fi' system in another room.
Hope this helps
