how to connect audiophile 192 ?
Permabanned
19 Oct 2007
I need to connect my soundcard to my amplifier. for amp i use a numark pa amp that allows balanced / unbalanced xlr in, or unbalanced 1/4 jack.
the soundcard has 1/4 jack outputs, l/r seperate ones.
so can i just use 1/4 jack - 1/4 jack x2 connections ? as im not sure if the soundcards outputs are balanced or unbalanced.
thanks
Only way your gonna get it balanced is by going 1/4 jack (TPS) from soundcard into the XLR input on your amp. If you go into your amp's 1/4 jack (TS), then it will be unbalanced, even though your outputs on your soundcard are balanced.
is there a 1/4 male - xlr male connector available anywhere ?
as im just using the sub for mono duties can i use just the L or R 1/4 off the soundcard or do i need a 2-1 splitter to then go to the xlr ?
