just about to build pc phanteks eclipse p600s with with ryzen 3700x rtx2070 super 450 thomahawk max board I never build before just read you need to discharge your bodys static electric charge how can I be sure I'm doing this safely while building
the radiator touching does nothing as you need to touch bare unpainted metal, i.e. the pips underneath if these are bare copper.Touch a radiator now and again. Or if you’ve got the PSU installed, plug it in (keep the PSU off though) and touch a metal part of the case.
I honestly wouldn't worry about it too much unless you have a nylon carpet.
Got any pics of this so we can help you diagnose the issue?ok guys im stuck at trying to install h100i rgb platinum se to thomahawk 450 max board back plate wont line up
It's really not worth worrying about it. Just don't do skids on your carpet in trainers and then fondle your components.
ok thanks I was wondering about the painted radiator
If you have spent that amount of money on all those new parts then why not spend a fiver on an anti static wrist strap and cable with croc clip?
