How to fix these holes?
You need a welder... and a lot off time. Thats roughly what the dodge looked like... take it back and try welding you'll find its just rust for another few inchs..
agw_01 said:
Thanks for the reply SKILL.
How do you mean though... will it start rusting again or will the filler eventually crack and fall out?
Could anyone shed some light on this? How far inside the sill should I treat with Waxoyl/Hammerite? Any how much of the surrounding metal should I cut away, if any at all?
Cheers :)
Wouldnt bother preping it yourself, leave it upto the guy who will do the job. Guy i take my cars to for spraying etc has to near enough redo everyone elses "preps" :)
Cool, cheers guys :)
Car is going in as soon as I get paid.
On another note.. got my tub of copper grease today. Hopefully get the 'zorst on over the weekend :D
Well, looks like welding is a definite.
Drilled out the screws holding the side spats on, as I wanted to make sure it was all clean underneath, and what do I find...
Nothing.
Nothing as in, no metal! Just nice big gaping rusty holes :)
