The message has hit home!
Enjoy![]()
Sure has mate
Thank you for your help
Cheers mate
Enjoy![]()
What do you mean by "not better"?
They're not going to look any different at the same settings.
Overclocking should just increase the frame rate or allow you to use slightly better settings at a similar frame rate.
IM always in and out the BIOS in nvidia - if you like a bit of code editing just go in with a bios editor and modify the correct fields - save the bios - and then apply it to the card..
I tend to use AB to test before hand though.
