How to whiten teeth?
Status
Not open for further replies.
Do you mind linking a good place to buy them pal? I'm just about to go offline, and not having to search on google later would be a big help :)
Boots chemist?
Teeth aren't naturally white for most people. Have a look at early 80s films and you'll see what I mean.
Don't compare your teeth to people on the TV with Veneers.
From what I know (which may not be much) it is recommended to:
1. Wait at least 20-30 mins after eating before brushing your teeth as the enamel is soft due to the acid build up.
2. Do NOT rinse your mouth with water etc as this will leave a thin layer of toothpaste on your teeth allowing more fluoride absorption
3. Do NOT use mouthwash immediately as this has the same effect as water in point 2. Wait about 20 mins.
Status
