Cheers for the input Ste!!
Sounds like you have done some experimenting yourself, I was going to buy the VDAC or CA dacmagic plus but was told the DAC on my yammy 1010 was good enough. There is another USB to SPDIF I looked at too.....can't remember its name now..
Found it > http://centrance.com/products/dacport/ not cheap though.
I have indeed....
Note that there's usually a difference between a DAC and an outboard asyncronous USB>SPDIF convertor. More expensive DACs nowdays are starting to do both but not many of the cheaper ones do. The VDAC II does both and would be a big step up over your recievers DAC.
