I've done something pretty stupid and am now at a loss. Took wheel off, took pads out. Discovered they weren't worn out after all, and just needed aligning. I realise now that I didn't need to remove them to discover this.
However I squeezed the lever while the pads were out, and the jaws of the device have closed by about 4mm. I now can't get the pads back on, or separate the jaws. Do I really need to drain the damned thing, or should I just be rougher with a screwdriver/pliers?
Cheers
(avid juicy 3, for difference this makes)
Cheers
