1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
I cant drive using a wheel and pedals for Toffee!!
Discussion in 'Gaming Peripherals' started by beany_bot, Jan 12, 2018.
  1. beany_bot
    Wise Guy
    So I have an Dirt rally and Project Cars 2 and I just got an Oculus rift. Obviously very exciting. And obviously for immersion the controller has to go.
    So I got a logitech G27 setup from the MM.
    Thing is... I'm AWFUL. like terrible. I cant drive for toffee! Is this normal?
    I mean IRL I am confident I am a good driver, I've been driving for 20 years and have won a couple of amateur races at Knockhill in different classes. But I feel like such a noob using the wheel in games. I spin out constantly, lock up the brakes and am generally rubbish. I can't pinpoint why. Is it just because I'm not used to it? I kind of assumed that I would be instantly better than a gamepad because, well, it's more realistic. Is it because their is no fear?
    Do I just need to stick with it?
  2. Hedge
    Capodecina
    I was pretty bad at Dirt Rally initially. The key with that game is to slow right down. Your first priority should be to get to end of course without coming off too much. Then once you have it complete increase your speed a touch.
    Avoid having your foot to the floor until you are more dialled in. Also with Dirt rally you need only very small wheel inputs a lot of the time. It doesn't need to move full lock often on many courses.
  3. beany_bot
    Wise Guy
    Even project cars 2 though. I can't even get a 1600 MK1 escort round a track lol. Whereas I know I can easily do that IRL.
  4. wesimmo
    Wise Guy
    I find it difficult as you don't get the physical feedback you do in real life.
    Changing gear for example, it's less about the rev counter, I can just feel when I'm at the redline in real life, in games I have to watch more to make sure I don't bounce off the limiter.
    That feeling you get in real life when you're on the edge of grip and you balance the steering and throttle, force feedback will never replicate that entirely.
    You just need to learn the physical feedback from the Sim set up versus what you know in real life which will only come with experience.
  5. crinkleshoes
    Sgarrista
    I find it difficult too... didn't realise how much I drive with my butt until I tried playing games.
    VR helps thanks to the improved perception of speed... but it's still not there.
  6. TallPaul1878
    Wise Guy
    I blame the Logitech wheel. I received a Thrustmaster TMX that is a budget version of the TX wheel. It was a bit naff with regards to the plastic and rubber trim and the mechanism was not as good as a TX.
    I ended up returning it due to a blown cooling fan causing a terrible whining noise.
    After that I bought the Logitech G920 which has the same mechanism to the G27. It is nowhere near as accurate as the budget Thrustmaster in my opinion.
    But with a wheel and pedals you need to readjust your driving style. You've been used to a controller and the way you can easily flick an analogue stick from left to right.
    You should take time to learn to drive again image racing game. Pick a slow front wheel drive car in PCars and just get used to driving around and using the gears. Set faster and faster lap times. Eventually you will start getting quicker, you'll match your controller times and then you will eventually start beating them.
  7. beany_bot
    Wise Guy
    I think it's down to the vagueness of a PC compared to real life. As mentioned not being able to "feel" the grip, the engine and the g forces. In a real car on a racetrack you can very very quickly find it's limits of grip and breaking distances. As it slips the tiniest bit you know it. but in a game, it really needs to slide a lot before you know it's happened. FF no matter how good doesnt resolve this issue. And braking, you just dont get the forces involved and its so easy to over break. Anyway, I'm sure practice will help dial it in. Just hope it doesn't make me a crappy driver IRL!
  8. olivier renault
    Sgarrista
    It takes a (little) while to switch from controller to wheel.
    And you shouldn't expect it to be like driving a car down the road. There's no feedback apart from the wheel, and the wheel feedback takes getting used to, and feels ... weird.
    The pedals also are poor analogs of the real thing, but you get used to it as well.
  9. Westie
    For dirt rally change ya wheel rotation to 360 or 520.. will help alot..
    900 wheel rotation for dirt rally is way to much as I gather your running default wheel settings
  10. Telecaster
    Mobster
    Sounds like the same issue I had, the first problem I think is expecting to be any good at a game based on RL driving. They're about as realistic as playing some sci-fi spaceship flying sim lol.
    I think it's just a case of getting used to a wheel for games, you'll never replicate the butt dyno and physical feedback from real track driving experience.
  11. Rroff
    Capo Crimine
    I found Grid and the Dirt games to be very fussy about wheel - a lot you'd end up either super sensitive or super un-sensitive no matter the settings :(
    Not really spent a lot of time with project cars so can't comment on that but play a lot of Assetto Corsa and despite having the wheel dialed in pretty well I don't find the physics model reflects real life - understeer tends to be quite exaggerated especially with automatic gears - I've driven some of the tracks IRL with moderately performing cars way better than I can manage in AC.
  12. David230
    Hitman
    It might just need a few tweaks here and there to make all the difference. Config or game settings or both..
    I found driving in assetto corsa actually helped with certain aspects of real life driving. The same way actually being let loose on a testing ground where you had space to make mistakes but learn as you go.
  13. Rroff
    Capo Crimine
    Possibly its a config issue - apparent AC also doesn't tend to like automatic gears with regard to grip - state my wheel is in I tend to use automatic.
    Some of the corners though on some tracks - I've entered at ~50mph IRL and the car has handled it fine - far more in the car infact than my level of skill while same car and track in AC anything more than 30mph and once you hit the apex you slide off one side irrespective of what you do. Last Christmas (2016) I had AC setup with the wheel on a projector as we had a few family over who are into fast cars and do track stuff fairly regular and they all commented on it as well - still possible its a configuration issue on my end but I've spent hours going over it trying all sorts.
  14. Parky
    Wise Guy
    I'd echo the suggestions above, spend a little time tweaking your setup until you find something that feels a little better. Every game is different so don't expect to be able to transfer your skills straight away from one to another either. It can feel off putting at first, but once you start getting to grips with the feel of the game your enjoyment level will really increase.
    I really wouldn't worry about being unable to transfer your real world driving skill into the game, it doesn't really swing that way unless you are going for the die hard sims. The lack of feedback, fear factor and general sense of speed are always the biggest things that are hard to get your head around. Just take things slow and learn the basics again with slower, more manageable cars. You'll soon start developing the control and understanding of the physics for that particular game.
    I played Gran Turismo 5 loads when it was released, but never really pushed myself or delved into the tuning options, even though I had a wheel I still had to use all of the assists. When GT6 came along I really jumped in and learned to drive without assists, but also learned how to set up cars properly. It's probably the most dedicated I've been in a game, but I also had the most fun I think. I owe a lot of that to jumping into well disciplined multiplayer races, studying people's ghosts on time trials and generally reading into other people's setups for both their cars and sim setup, but also how they tackle each track with that setup.
    See if you can find any friendly groups to play with that have regular race nights, you'll be surprised by how much you will adapt and learn just by following others around the track, even If you do come last.
  15. Pyr0m@nI@]{
    Gangster
    I found exactly this on the weekend
    I'd bought a playseat challenge to be able to use an old Logitech dfgt wheel (wheel doesn't like my desk) in pcars2 and I suck at it, it's much easier on an xbox pad lol
    I'm going to stick with it for now, but I know the config needs changing as the wheel feels too heavy when steering.
  16. NirK
    Mobster
    I find the braking difficult with pedals, on the wheel I have it has a "conical brake mod", which makes braking more consistent, I also got a replacement rubber bit for it from ebay and its quite good now, although I guess a load cell would be better, but yes that's probably why you lock up the brakes because the G27 pedals do not have any resistance, I think you can get a load cell mod for the G27 pedals.
    Also try download custom FFB files for the games, some of them, cannot remember the name now, think it is jack spades FFB files, are quite a lot better than the default setup.
  17. NeverWinter
    I now have the Fanatec CSR Elite pedals which have a load cell (which are great), I used to use a G25 and often found myself easily locking up the wheels. I installed the Nixim brake mod to them and found my braking became far better as you get a sense of when the lock-ups will occur from the pressure you apply rather than using distance with the standard setup.
    It is different to real life driving/racing as there is less feel (sound is an important factor in sim racing also), you will get better with practice, keep at it.
Share This Page
