- 1 May 2003
I have an 4870, and I don't see the point in upgrading just yet. I am still playing all the new games, without any issues. I will be waiting till Q2 next year.
if i had a sli board i'd be buying another one at the prices they are now![]()
I hope they're as good (and quiet!) as people say
A good friend of mine says it's virtually silent or at least he can't hear it over the rest of his system. He hasn't even overclocked it any further either because he can play all the games he has on max settings @1650x1050 anywayI broke down and ordered the Gigabyte GTX460 1GB OCI hope they're as good (and quiet!) as people say
The 460 is known to overclock extremely well and easily. Whilst there's never a guarantee you'll get an amazing overclock as each card has slight differences, you can be pretty certain the 460 can reach near 800Mhz without any voltage change. At this level, it's near the 6870 (which as you say overclocks badly) and can be had around £150.1) 6870 = for £170 ( quiet / efficient / low power draw / eyefinity / overclocks poorly )
2) 470 = for £180 ( phisx / overclocks well / loud / hot / massive PSU draw )
3) 460 = errr skip it me thinks. overclocking is never a guarantee.
4) 5850 = skip it too not worth it.
Yea. At GTX460's 1GB current price I wouldn't consider getting one...just yet, considering that a Sapphire 6850 with a Vapor-X like custom cooler can be bought at £132. If the Gigabyte/MSI Cyclone GTX460 1GB drop to around £130, then I would probably get one...they can keep the HAWK 2 download vouncher for all I care.I personally thing that the HD6870 overclocking is limited by the BIOS just as the HD3870 and HD5850 were initially. Give a week or two and I will suspect that better HD6870 overclocks will be seen. Anyway, I would not got a GTX460 1GB over an HD6870. A GTX470 OTH is a better choice IMHO if you want to stay in the Nvidia camp as in many places it is not that more expensive than overclocked GTX460 1GB cards. Also,some websites have got HD6850 cards to around 900MHZ for the GPU so it maybe also worth considering this card too.
Peter450 said:I dont get were everyone goes on about a 470 being noisy??? at stock fans speeds it's not noisy at all, mine runs a little louder as i have OC it but still at stock or near stock fan, it's quieter than my case fans, which are fairly quiet IMO
The main problem seems to stem from the fact that all 470's are different, some require higher voltages at stock speeds whereas others simply don't.
The 460's appear the same:
My Sparkle runs stock volts of 0.937v whereas my Inno3D 460 runs 1.037v. To get 850 core the Sparkle needs 0.962v whereas the Inno3D needs 1.062v. Correspondingly the Sparkle runs cooler and quieter.
