I have a BLUE Screen Help!
3 Feb 2007
Preston,Lancashire
Hi
I recently started getting this blue screen, so I swapped my 560Ti for my works AMD 6950 and updated the graphics drivers, I still get this message , it quite random?
Please help?
The PC Spec
Gigabyte GA-EP45-UD3LR ( 2years old original Bios )
Q6600
4 sticks of Giel 1 gig Ram
New Sammy 840 SSD 2 months ago.. running Windows & 64bit
did you completely uninstall all the nvidia drivers and utilities before installing the amd ones? conflicting drivers is a good way to cause some bsods
Hi yes I did, installing the AMD was only to test if the Nvidia was faulty, the blue screen was there before the AMD swap.. both graphics have the same fault.:confused:
It could be a corrupted OS, try reinstalling Windows
Here is a list of BSOD codes
http://www.xtremesystems.org/forums/showthread.php?266589-The-OverClockers-BSOD-code-list&p=4741293&viewfull=1#post4741293
The OverClockers BSOD code list
BSOD codes for overclocking
0x101 = increase vcore
0x124 = increase/decrease QPI/VTT first, if not increase/decrease vcore...have to test to see which one it is
on i7 45nm, usually means too little VVT/QPI for the speed of Uncore
on i7 32nm SB, usually means too little vCore
0x0A = unstable RAM/IMC, increase QPI first, if that doesn't work increase vcore
0x1A = Memory management error. It usually means a bad stick of Ram. Test with Memtest or whatever you prefer. Try raising your Ram voltage
0x1E = increase vcore
0x3B = increase vcore
0x3D = increase vcore
0xD1 = QPI/VTT, increase/decrease as necessary, can also be unstable Ram, raise Ram voltage
0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances
0x50 = RAM timings/Frequency or uncore multi unstable, increase RAM voltage or adjust QPI/VTT, or lower uncore if you're higher than 2x
0x109 = Not enough or too Much memory voltage
0x116 = Low IOH (NB) voltage, GPU issue (most common when running multi-GPU/overclocking GPU)
0x7E = Corrupted OS file, possibly from overclocking. Run sfc /scannow and chkdsk /r
BSOD Codes for SandyBridge
0x124 = add/remove vcore or QPI/VTT voltage (usually Vcore, once it was QPI/VTT)
0x101 = add more vcore
0x50 = RAM timings/Frequency add DDR3 voltage or add QPI/VTT
0x1E = add more vcore
0x3B = add more vcore
0xD1 = add QPI/VTT voltage
“0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances”
0X109 = add DDR3 voltage
0x0A = add QPI/VTT voltage
If I have to re install the OS I'll buy a new MB,RAM & CPU, mine have been totally reliable for 4 years but a change is coming.. :D
Thank you for your input guys...
