This is the motherboard I'm going to get. All 4 ram slots will be full.
What air cooler would be good for a 8700K?
Thanks
Thanks
Depends how far you want to push the overclock, if overclocking then delidding is also pretty much a prerequisite, or if you only want a moderate overclock then most £30-£50 tower coolers should be good.
The team group vulcan stuff is very low profile, and unless you go for a mahoosiive heatsink, it's only the first 2 ram slots you need to worry about.
Personally, big ram fins are a waste of time, they just look flashy.
What RAM and case are you using?This is the motherboard I'm going to get. All 4 ram slots will be full.
Thanks
My basket at Overclockers UK:This is the motherboard I'm going to get. All 4 ram slots will be full.
Thanks
Thanks to this design, not a single RAM slot is being obstructed by the cooler on most motherboards on the market, not even when the fan is installed on the front side in a pushing configuration as it is most commonly done. Nothing stands in your way when you plan on using all RAM slots on your board.
With the central positioning of the heatpipes and the heat sink to the base plate, the CPU cooler can be installed in such a way that it does not protrude over the RAM modules. RAM modules with their own oversized heat sinks can also be installed, regardless of which direction the Cryorig H5 Universal is placed in.
- 1 x Alpenfohn Brocken 3 CPU Cooler - 140mm= £42.95
- 1 x Cryorig H5 Universal Single Tower Heatsink with 140mm Fan - White Frame= £44.99
These should both work for a reasonable overclock, and both say they won't obstruct RAM.
Alpenholm:
Cryorig:
ASRock Z370M Pro4 has about 77.9mm center CPU to near side of PCIe socket and 52mm to near side of RAM socket.
Thermaltake Core V21 has 185mm CPU clearance so plenty of room for cooler. Fan over RAM is fan size + RAM height <190mm
Have no experience with Core V21, but looks kinda interesting. Had a couple very bad experiences with Tt long time ago and see them stealing other companies' designs, so haven't used and don't plan to use anything Tt.
Thanks for update.
Look forward to hearing your thoughts after it's built with case airflow setup properly.
65c is fine, 80c is to me at least 5c too high for sustained lengths of time.I done a overclock via the Asus overclocking in the bios.
CPU-Z says it's 5.1 GH and the temps are 65c @1.34V. That sound ok for a 8700k cpu?
I have no clue what I'm doing on the motherboard
EDIT= I just tried Cinebench a few times and it went up to 80c is that to high?
It says my CPU is 1614cb?
I don't have an 8700 so don't know what recommended setting are. Hopefully someone who is knowledgeable about 8700 overclocking with reply.
