i5 2500k and Gigabyte Z68 guide
23 Dec 2004
Devon
Hi,
I need a bit of help.
My cpu will run stable at 4.5ghz but when under load ie prime 95 the volts go up to 1.38-1.39 which I believe is too much.
I have set the cpu voltage to 1.35 in the bios but the volts still go up under load.
What other voltage settings do I need to alter to stop it from putting the volts up too much ?
I have done a bit of research online but not really found anything regarding the bios voltage settings for the Gigabyte Z68 chipset.
Thanks for any help.
