The 1366 platform will be especially good if Intel releases a £200-300 Gulftown once their next generation CPU hit the shelves.
I feel gravitated to the i7
Hey Arthalen!
There is a phenomena akin to an "Event Horizon" with the Intel® Core™ i7 . . . once it's gets a hold there is nothing you can do to stop yourself getting sucked in . . . . good luck!![]()
Quick Suggestion, You'd be better off with a "Asus P6X58D-E" For the i7 rather than a UDR3. The rev2 version is apparently slower than the original not to mention the PCI-E lanes are better for Crossfire or SLI on the P6X58D-E and you can pick one up for about £140. even if it means using a rival site just for the mobo it's well worth it.
Also I have an i7 it's future proof. even with the most intense game my CPU usage doesn't go over 50.![]()
Firstly, thanks for everyone's replies.
I've made my purchasing decision, and its going to be the i7 950.
Consider what I've said and take a look at 2nd hand 920/930s.
You'll save yourself over 100quid and both 920/930 will clock to the same speeds as 950 and provide identical performance clock for clock.
And remember to get a nice LARGE case with good features to keep your things cool and allow you in the future to install extra GPUs/HDDs.
