KRU Shotgun said:
What are the auction sites for guitars?
Would anyone have any suggestions to guitars to buy i like the Ibanez/Jackson Styles
This 1 has DiMarzio,s
Thx Shotgun
That's a Jem555, the budget Jem.
It's basically an RG with the body routes, and a worse trem. It features the Edge pro 2, this is the trem which is the next step up from the one in the RG370 (which has the Edge Pro 3).
The Jem7v which I have, has the Edge Pro (mine is an older model so has the lo-pro). Basically if it's a Japanese made Ibanez it'll have an Edge Pro, if it's a Korean made Ibanez it'll have an Edge Pro 2, if it's Indonesian made it'll have a Edge Pro 3.
The Jem555 really isn't worth the money. It's got DiMarzio pickups but still has a worse trem. It's cheaper to buy an RG550 and replace the pickups, than try and replace a Edge Pro 2 trem to something better, you can't just swap the bridges over either as the body routing for the Edge Pro 2 is different to that of the Edge Pro, and you can't replace any Edge Pro trems with the earlier Lo-Pro or Edge trems either as the routes are completely different.
I'll say it again as it really is the best option if you want the best guitar for your money: Go secondhand and get an RG 5 series! *pulls hair out*
alexthecheese said:
Anybody know anything about the Ibanez S470's? How do they compare to the RG's?
They have 22 fret necks instead of the RG's 24. They also have a more curved and slim body design. The new S470s also use the relatively new Ibanez ZR (Zero Resistance) trem. It still has the crappy INF pickups, but those can of course be changed.
The ZR trem is a bit of a more complicated unit than the Edges, it has a stabling arm which works to stiffen up the trem slightly.
The S series is completely different to the RG series really. You've got to try one out to see what you think, you might not like the feel of the trem.
The biggest difference is the body shape really, I find either just as comfortable.
