Idiot with paintshop pro 6 and animation shop
20 Mar 2004
I've been trying to make a emoticon with PSP 6 and animation shop 2, only something simple to start with.
I got a guide but it seems to cover a different version of PSP.
I created my basic model with no problems, different layers for body, eyes, hands etc.
I saved each frame as a .gif and inserted it into animation, all seemed to work fine, except that it doesn't have a transparent background, even though the original model .psp is transparent
A friend suggested I cut out each frame, paste it back in PSP, use to magic wand then put it back into animation, for some reason the frames were twice their original size, so I had to reduce them and the body seems is no longer central in the image, as the hand moves up, the body moves down? The image quality is also pretty crap.
Any idea on where I went wrong to start with :confused:
Edit - Nevermind, figured out a quicker way to do it, hence why the 1st smile is transparent now, was up till 5 in the morning sorting it out, thankfully no work today.
My 1st lil emoticon
