I'm buying a MSI 7970 Lightning this friday and need help.
Yes that cable that has 2pins loose when combined together would give you 1 of the 2 8pin connections for the 7970. However, you only have 1 other 6pin PCI-E cable and therefore don't have enough to make up the 2 you'd require to connect into the adapter cable shown above to combine 2 6pin PCI-E cables to make 1 more 8pin for the 2nd connection onto the gfx card. In short I think you need a better PSU so that you have 300W of power via PCI-E connections to supply the gfx card.
So I'm short one cable?
So what PSU should I buy? I only have maybe £65 to £70 to spend If I have too? So you're saying the 7970 Lightning is too much for my PSU?
the pic shows he only has 2 x 6 pin
there are no 2 pins loose thats a solid 8 pin connector with only 6 pins used :eek:
How bizarre!!!
Ive never seen a 8 pin connection that you get with the psu only have 6 cables.
Its only 75 watts if it only has 6 cables. With this info id defo get a new psu
This is what id get if it were me
http://www.overclockers.co.uk/showproduct.php?prodid=CA-003-XF&groupid=701&catid=123&subcat=1497
super stable power down one rail. it has 2 x 8pin and 2 x 6pin so plenty for all your needs without drawing to many watts from the wall.
Would that fit in my cit vantage case
What if I just got another cable like the one of my gpu I have now? would the psu still be ok for the card or not?
personally I think ocz psu are total crap. I put one in my kids machine same one as yours I think and it lasted a month.
I have seen others suffer the same fate in the forums as well and would no way trust it with a £300 graphics card. and a million percent no with the wrong cables
On paper it should deliver but in reality I dont think it delivers a stable 600 watts 100% of the time. My answer would be no way
I'm guessing you were looking at the original picture which I'm guessing is the only 6pin PCI-E with an 8pin PSU connection block utilising only 6pins. The one I was referring to was the one shown attached to the existing card with the separate 2pin connection hanging loose.
Ok I'll buy that PSU you linked. Gaming on PC is not cheap:(
Thanks for all your help, you've been a star mate:)
Cheers
I see mate
if it comes out the supply on 6 cables It could have 20 pins on the other end its still only 75 watts.
Cheers
No problem buddy :)
That xfx psu is made by seasonic inside (best psu maker there is)
has one large rail which is great for gaming instead of power split over 5 rails
has a very high power factor which means it wastes very little saving you money
I have the 1000w xfx platinum in mine and its the dogs bol locks ;-)
After all this and because of the PSU I can't afford the 7970 lightning:( It's a little over my budget. So I guess I'll have to get the MSI 7950 TFIII instead. I should still be happy with the speeds after reading reviews.
