I'm quite happy so far. I haven't noticed any dead pixels, although I've not had the chance to see against a white screen an I really can't be bothered to plug it into the PC. I just tried the headphone jack which was AWFUL. No static, that I could hear, although I had to turn the volume up to 100, an increase the in-line volume of the headset to get a OK-ish volume to listen to. The audio was very tinny from the headphone jack. It renders it completely useless. What's your audio port like?
As for colours, backlight bleed, response. All good so far. Speakers are mmmm, adequate, bit tinny, pretty much no base, but will suffice. No distortion, yet. Which is good. I'm sure GT5 will put it through it's paces.
In terms of backlight. I think I have the first ever panel in the universe which has... none. Well, at least on the standard and game setting.
Any descriptions for your audio HP quality/volume, the speakers bass depth, backlight bleed, what setting etc. Just so I can get to grips with what's similar and if there are any differences.
So far, quite happy. Slight warping in the frame on the bezel, which does funny rippling to reflections, but I don't know if that effects all of them or not. lol
It appears, labelling sticker/fabric/sheet thing which overlays the ports and has the names of the ports written on is, unstuck, not stuck down properly, of simply... that way, an then of course the worst stand in history. By no means did a machine make it. A human did, with wonky eyes. LOL. Things facing off by about 20 degrees. It's mental lol.
I'ma check some blue rays out. Responsiveness is quite good. Not noticed any ghosting yet. The ZA.BEKWLJP means I Have IPS right?
Thx btw
