- 18 Nov 2019
Black is for all seasons.They look more Halloween than Christmas to me. Where from ? I think my oldest daughter could have some fun with those.
I just showed my local salon the picture.
Fitting a smart TRV doesn't suddenly stop the normal TRVs from working exactly as they did before.Thanks for the explanation but I'm still confused. If I understand correctly you can't just have one of these on one rad in the house because when that one TRV calls for heat it will heat the other rads with dumb TRVs with it. You would have to have them fitted to every radiator in the house to keep the others rads from heating if you only wanted to heat for example an office room radiator during the the day?
The other perk of a smart TRV being that they can ask the boiler to come on when a specific room drops temp.Fitting a smart TRV doesn't suddenly stop the normal TRVs from working exactly as they did before.
It just means that every radiator with a smart TRV can be individually controlled via scheduling and geofencing, meaning you can automatically allocate less heating energy to rooms you don't need to be warm at a given point, rather than having to go round and turn them off manually.
What you may not have clicked is that the central heating water feed goes to all(*) radiators individually, they're not a series loop one after the other. The pipes go past each radiator and split off a little branch for each one.Thanks for the explanation but I'm still confused. If I understand correctly you can't just have one of these on one rad in the house because when that one TRV calls for heat it will heat the other rads with dumb TRVs with it. You would have to have them fitted to every radiator in the house to keep the others rads from heating if you only wanted to heat for example an office room radiator during the the day?
So yes you have one TRV (or just a manual valve) per radiator to control the flow through each. They work by limiting how much hot water they take in, and letting the rest bypass them.
Edit: a TRV is a valve, not a smart signal that calls the boiler.
For clarity a Tado smart TRV does call the boiler directly.What you may not have clicked is that the central heating water feed goes to all(*) radiators individually, they're not a series loop one after the other. The pipes go past each radiator and split off a little branch for each one.
@the-evaluator nice, where did you get it from? I’m after something pretty much the same.
Solar powered PIR floodlight to go on the front of the shed. Seems to work really well so I'll order another to go above the French doors.
Thanks. Only IP44 rated so I'm not too sure how well it would fair in the UK climate outside.
To be fair most of them are the typical 'bought and and can't fit it so I'll leave it 1 star' type reviews. But it's the IP rating that concerns me. I'm wondering whether to pay an electrician to install proper lighting that I know I won't have to touch (except bulbs) or try and do it on the cheap... and potentially have to pay for it again in a year or so.I also want something similar for outside, the one above doesn't have the greatest reviews but I can't see the comments..
Haha I was going to say the sameI spy a kamado.
