**INCREDIBLE MSI GRAPHICS CARD DEALS!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Lots of new MSI cards in stock and for the weekend were offering them at some truly stonking prices:-
MSI ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card @ £191.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- ATI Reference Design (Revision: 1) - Flashable too 6970
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Card Dimension(mm) 275*110*38mm
- Warranty: 2 Years
Was [£209.99] Inc. VAT
Only £191.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6950 Twin FrozR II 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
Features:-
- Core Clock: 810MHz
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was [£214.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6950 OC Twin FrozR III Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £209.99 inc VAT
Features:-
- Core Clock: 850MHz
- Memory Clock: 5200MHz (Effective)
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was [£224.99] Inc. VAT
Only £209.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6970 Lightning 2048MB GDDR5 PCI-Express Graphics Card @ £299.99 inc VAT
nonl2br
<img src="http://uk.msi.com/marketing/images/AMDLightningStatic.jpg" alt="MSI Lightning" /><br>
<br>
These cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. Industry-leading Power4 architecture and Twin Frozr III dual-fan cooling with innovative Propeller Blade technology brings together a solid power supply with advanced cooling technology. This results in huge boosts to overclocking potential and stability, enabling the air-cooled N580GTX Lightning to break the 1GHz core clock barrier with ease. The Lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records! <br>
<br>
<Font size="5"><b>Key Features</b></font><br>
<br>
<img src="http://uk.msi.com/marketing/images/power4.png" width="210" align="left" alt="power4" /><b>Industry-leading Power4 Architecture for Overclocking Reliability</b><br>
Inheriting the impressive Power4 architecture from previous Lightning cards along with improved components and design in four areas. The PWM module is twice as large as before and provides double the amount of current to the GPU. Memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. The next-generation Proadlizer capacitor increases signal stability by leaps and bounds while CopperMOS, the industry's best MOSFET, provides the GPU with a large and stable power supply. Combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there. <br>
<br>
<img src="http://uk.msi.com/marketing/images/lightningsplit.png" width="210" align="right" alt="Cooling" />
<br>
<b>Twin Frozr III and Propeller Blade Technology Takes Cooling to the Next Level</b><br>
The all new Twin Frozr III cooling design utilizes the innovative Propeller Blade technology to double the amount of airflow compared to conventional fans. The airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm PWM fans, SuperPipe technology, and the Form-in-one heatsink, the result is GPU operating temperatures 26°C lower than the reference board when the 6970 Lightning are operating under full loads. Fan noise is also 11dB lower in addition to having much higher overclocking potential.<br>
<br>
<img src="http://uk.msi.com/marketing/images/afterburner.png" align="left" alt="afterburner" /><br>
<b>Overclocking Potential Unleashed with GPU/Memory/PLL Triple Overvoltage</b><br>
The MSI 6970 Lightning graphic cards come with the latest version of MSI's exclusive Afterburner V2.1.0 overclocking utility. The utility not only adjusts GPU and memory clock but also manage the GPU/Memory/PLL(VDDCI) voltages to maximize overclocking potential. Thanks to Triple Overvoltage, the overclocking potential of 6970 Lightning is much higher than the reference board and offers enthusiasts ultimate performance.<br>
<br>
<br>
<br>
<b>King of Extreme Overclocking</b><br>
For hardware enthusiasts, the MSI 6970 Lightning graphic cards come with exclusive extreme overclocking features. Apart from V-Check Points and V-Switch for monitoring and adjusting the GPU/Memory/PLL(VDDCI) voltages in real time, Dual Bios switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. PWM Clock Tuner also helps to increase overclocking potential. All of these come together to make the 6970 Lightning the ultimate graphic cards for extreme overclocking<br>
<br>
<img src="http://uk.msi.com/marketing/images/mcii.png" align="right" alt="Military Class" /><b>Carefully Selected Materials</b><br>
The MSI 6970 Lightning graphic cards use top-quality Military Class II components including All Solid Cap for overclocking and full-speed operation, SFC for 10% higher efficiency, and 30% increase in maximum current, as well as Hi-c Cap with Tantalum core which boasts 8 times the lifetime of conventional solid capacitors. These high-quality components not only increase the graphic cards' overall service life but also enhance GPU stability.
<br>
<br>
<img src="http://uk.msi.com/marketing/images/MUSTHAVE.png" alt="Kit Guru Gold" />
<br>
<br>
<Font size="5"><b>Specifications</b></font><br>
<br>
<b>Stream Processors</b> - 1536 Units<br>
<b>Core Clock</b> - 920 MHz<br>
<b>Memory Clock</b> - 5500 MHz<br>
<b>Memory Size</b> - 2048MB GDDR5<br>
<b>Memory Bus</b> - 256 bits<br>
<b>Output</b> - Mini DisplayPort*2 / HDMI / DVI*2<br>
<b>TDP</b> - 269 W<br>
<b>Card Dimension</b> - 310x127x40mm<br>
<b>Form Factor</b> - ATX<br>
<b>DirectX 11</b> - Y<br>
<b>OpenGL 4.0</b> - Y<br>
<b>CrossFireX</b> - Y<br>
<b>Eyefinity</b> - Y<br>
<b>AVIVO HD</b> - Y<br>
<b>PowerPlay</b> - Y<br>
<b>HDCP</b> - Y<br>
<br>
- World’s first 18 phase PWM on HD 6970.<br>
- Independent Memory Power support. <br>
- Copper MOS with 2x high current capacity. <br>
- Proadlizer*4 to optimized power supply. <br>
- Twin Frozr III Thermal Design with 26C cooler & 11dB quieter. <br>
- Propeller Blade technology for 20% more airflow. <br>
- Dual 9cm fans with dual 8mm SuperPipes for best heat dissipation. <br>
- Form-in-one heatsink covers memory and modules to dissipate heat efficiency.<br>
- Support voltage adjustment of GPU/Memory/VDDCI<br>
- Military Class II Components for longer product lifespan. <br>
- LPL (Lightning Power Layer) for the stable power supply.<br>
- Usage of the Micro/DIP switches on rear of card voids warranty - For extreme/expert overclockers ONLY!<br>
Was [£319.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 5850 Twin FrozR II 1024MB GDDR5 PCI-Express Graphics Card @ £129.98 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 5800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 725MHz
- Twin Frozr II Thermal Design
- Voltage adjustment
- Ideal for overclocking
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Bandwidth: 256
- Processing Cores: 1440
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI & 1 DisplayPort
- HDCP Capable
- OpenGL 3.2 Support
- ATI CrossFireX Ready
- ATI Avivo HD
- 2yr Warranty
Was [£139.99] Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
MSI ATI Radeon HD 5450 512MB SILENT GDDR3 PCI-Express Graphics Card @ £24.98 inc VAT
The MSI ATI Radeon HD 5450 graphics card offers everything you need for gaming and HD home entertainment in one package. Do more on your PC with ATI stream technology, which accelerates even the most demanding applications. See more with ATI Eyefinity technology, providing the ultimate gaming experience by allowing up to three displays from a single graphics board. The MSI ATI Radeon HD 5450 fully supports Microsoft DirectX 11 which enables real-time rendering with ultra-realistic characters and incredible 3D imagery.
- Core Clock: 650MHz
- Memory: 512MB GDDR3
- Memory Clock: 1200MHz (Effective)
- Processing Cores: 80
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI
- HDCP Capable
- ATI Avivo HD
- SSC (Solid State Chock) has No Buzz noise and higher current for better overclocking ability.
- All Solid CAP for longer lifespan.
- Supports both 1080P HD movie playback and 7.1 Channel audio transmissions.
- Extra Large heatsink for the best heat dissipation and zero db noise.
- Work perfect with slim or smaller system.
- 2yr Warranty
Was [£26.99] Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
MSI ATI Radeon HD 5450 1024MB GDDR3 PCI-Express Graphics Card @ £29.99 inc VAT
- Memory: 1024MB GDDR3
- Memory Clock: 1600MHz (Effective)
- HDCP Capable
- ATI Avivo HD
Was [£31.99] Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
MSI GeForce GTX 570 OC Twin FrozR III Power Edition 1280MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- Core Clock: 770MHz
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1280MB GDDR5
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1540MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 2 years
Was [£279.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
MSI GeForce GTX 560Ti OC Twin FrozR II 1024MB GDDR5 PCI-Express Graphics Card with FREE Assassins Creed 2 PC Game @ £185.99 inc VAT
nonl2br
<img src="http://uk.msi.com/marketing/images/560tfiibanner.jpg" width="768" alt="Hawk" /><br>
<br>
<Br>
<font size="4"><b>Key Features</b></font><br>
<br>
<b>Twin Frozr II Thermal Design 20 Degrees Celsuis Cooler!!</b><br>
- Dual 8CM PWM Fans for 50% more air alow can cool down GPU/Memory/Power Module at once.<br>
- Four heat pipes with SuperPipe Technology<br>
- Nickel-plated Copper Base : Large size of Copper Base can dissipate the heat of GPU faster.<br>
<img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf01.jpg" align="centre" width="220" alt="Triple Over Voltage" /><img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf02.jpg" align="centre" width="220" alt="Triple Over Voltage" /><img src="http://eu.msi.com/pic/image/product_img/other/vga/400/N460GTX-HAWK_tf03.jpg" align="centre" width="220" alt="Triple Over Voltage" /><br>
<br>
<b>7+1 Phase PWM Design</b><br>
- Higher current to GPU Powerv
- Higher overclocking capability<br>
- Better stability in peak load <br>
<br>
<b>Military Class Components</b><br>
- Hi-C Cap provides more precise GPU voltage.<br>
- SFC (Super Ferrite Choke) : 30% Higher Current Capacity, 10% Power Efficiency Improvement.<br>
- All Solid CAP for longer lifespan. <br>
<br>
<img src="http://eu.msi.com/pic/feature/features_20091001175702.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/pic/feature/features_s113_20080924184632.gif" align="left" alt="MSI" />
<img src="http://eu.msi.com/pic/feature/features_s114_20080924184756.gif" align="left" alt="MSI" />
<img src="http://www.msi.com/pic/feature/features_20101116171850.jpg" align="left" alt="MSI" /><br>
<br>
<br>
<br>
<br>
<br>
<BR>
<BR>
<br>
<font size="4"><b>Specifications</b></font><br><br>
- Dual 8cm PWM Fans for 50% more airflow.<br>
- Superpipe technology and nickel-plated copper base for better dissipation<br>
- 20c cooler than reference design<br>
- Military Class II Components<br>
- Core Clock: 880MHz <br>
- Memory: 1024MB GDDR5<br>
- Memory Clock: 4200MHz (Effective)<br>
- Memory Interface: 256-Bit<br>
- Processing Cores: 384<br>
- Shader Clock: 1760MHz<br>
- Bus Type: PCI-Express 2.0<br>
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)<br>
- SLI Ready <br>
- HDCP Capable<br>
- DirectX 11 Support<br>
- OpenGL 4.0 Support<br>
- PhysX Enabled<br>
- CUDA Enabled<br>
- 3D Vision Enabled<br>
- NVIDIA Surround Enabled<br>
- Warranty: 2 years<br>
- Supplied with Assassins Creed 2 PC Games
Was [£199.99] Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
