** INSANE DEALS: ENDING TOMORROW 9AM!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
Kind of a real short period, but just for the evening I am gonna blast some stock we have left when we purchased at good exchange rates in GBP favour, my re-buys for buying 100's/1000's are higher than what I am offering you some of these deals out, so do not miss out. To prove this simply check our competition we are vastly cheaper:
teamgroup xtreem lv 16gb (2x8gb) ddr3 pc3-21300c11 2666mhz dual channel kit (txd316g2666hc11cdc01) @ £99.95 inc vat
team xtreem lv is the most popular overclocking and gaming gear in the lan party. based on the memory architecture evolution on intel core i7, team raises the frequency of the xtreem lv ddr3 by 20% from 2000mhz to 2400mhz. also, by continuing the high frequency and low latency tradition of the xtreem lv memory, the xtreem lv ddr3 2400 can fully display the configuration 9-11-11-28 (tcl-trcd-trp-tras) at a low operating voltage at 1.65v without sacrificing either performance or stability. all these have witnessed the extraordinary r&d capacity and capability of team. in addition to the unchanged genuine chip policy, team ensures chip quality with the exclusive sorting technology to screen chips. in order to further ensure the optimal performance and flawless quality of the xtreem lv ddr3 2400, team applies the 24-hour burn-in test and industry-approved memtest software to perform the oqc inspection of all modules before shipping to assure the stability and exceptional performance of every xtreem lv ddr3 2400. the xtreem lv ddr3 2400 from team has a conventional 8-layered pcb design and is covered with the x-mark heat-sink labeled for the xtreem series. in addition to the clean appearance as found in all team xtreem memory modules, a groove has been added to the heat-sink for power users to install fans on top to enhance ventilation. for more information on this product, please visit the team group website at: www.teamgroup.com.tw.
features:-
- module type 240pin unbuffered dimm non ecc
- cl-trcd-trp-tras 11-13-13-35
- dram density 128x8 / 256x8 / 512x8
- data transfer bandwidth 21,300mb/sec (pc3 21300)
- heat sink aluminum heat-sink
- working voltage 1.65v
- warranty lifetime warranty
- note intel xmp1.3, compatible with series intel 7 chipsets and higher.
was [£149.99] inc. vat
only £99.95 inc vat.
order now
avexir core blue series 8gb (2x4gb) ddr3 pc3-12800c11 1600mhz dual channel memory kit (avd3u16001104g-2cw) - blue light @ £49.99 inc vat
nonl2br
<p align="left">
avexir core series is designed specifically for the extreme power users who focus on challenging the excellence in high performance gaming experience. the core series is developed by avexir r&d team with 10+ years’ experience of researching in memory core technology and designed specifically for the power users and gamers who demand ultimate performance and extreme reliability gaming modules.</p><br />
<center>
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/bgdyitv6s78?version=3&amp;hl=en_gb&amp;rel=0"></param><param name="allowfullscreen" value="false"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/bgdyitv6s78?version=3&amp;hl=en_gb&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="false"></embed></object>
</center>
<br /><br />
<p align="left">
avexir strictly adheres to quality standards set by jedec (the joint electron devices engineering council) and iso9001.</p>
<p align="left">
with 100% hand-tested extensively in multiple pc major-brand motherboard environments at its rated speed, avexir makes sure that both stability and performance of every memory module reach the highest quality criteria.</p>
<p align="left">
<b>features:</b><br />
- black pcb<br />
- black high performance heatspreaders<br />
- blue led strobe lighting effect (see product images)<br />
- spd programmed at: jedec standard 9-9-9-24 values at 1333mhz.<br />
- cas timings: 11-11-11-24<br />
- dual channel kit: (2x4gb)<br />
- 100% tested at 1600mhz in intel & amd based motherboards<br />
- lifetime warranty<br />
- sandybridge compatible<br />
- bulldozer compatible</p>
was [£59.99] inc. vat
only £49.99 inc vat.
order now
teamgroup vulcan red 16gb (2x8gb) ddr3 pc3-19200c11 2400mhz dual channel kit (tlred316g2400hc11cdc01) @ £99.95 inc vat
named after the god of fire in greek mythology, the team vulcan is the combination of high-end craftsmanship and top-notch technology. the short version heat sink of team vulcan prevents difficulty in installation due to large and bulky heat dissipation device of motherboard. the arrow-shaped opening design helps increase heat dissipation. in addition, the explosively red color combined with diamond cut pattern not only shows great texture but also the crazy sensation of over-clocking speed.
made of chips from major manufacturers, team vulcan passes series of harsh testing and verification procedures which have proven its stability and durability. currently, ddr3 2400 cl10, ddr3 2133 cl11, ddr3 1866 cl9/10/11 and ddr3 1600 cl9 are available to cover the mainstream dual- and quad-channel specifications that pretty much satisfy the demands of players of all levels.
features:-
- data transfer bandwidth 19,200mb/sec (pc3 19200)
- working voltage 1.55v-1.65v
- haswell & amd richland compatible
was [£129.95] inc. vat
order now
teamgroup vulcan red 8gb (2x4gb) ddr3 pc3-19200c11 2400mhz dual channel kit (tlred38g2400hc11cdc01) @ £49.99 inc vat
features:-
was [£65.99] inc. vat
order now
asus radeon r9 290 directcu ii oc 4096mb gddr5 pci-express graphics card @ £227.99 inc vat
get ready for half life 3 and gta v pc launch with an amd radeon 290 from asus in the form of this directcu ii oc graphics card, overclocked out the box and rewarded by our own gibbo as one of the best cooled and quietest 290's on the market, this is a card for anyone looking to play the latest or future titles to come.
asus, leading provider of high-performance graphics solutions, is now introducing the asus r9290-dc2oc-4gd5 which features 4gb gddr5 memory on board and supports directx®11.2 and opengl®4.4. asus exclusive directcu ii thermal with fansink and flatten copper heat-pipes directly contact with the gpu delivers 20% cooler and 3x quieter performance. digi+ vrm with super alloy power delivers precise digital power for superior efficiency, reliability, and performance. in addition to solid hardware specification, asus exclusive gpu tweak utility helps you to modify and monitor clock speed, fan performance and more, all via an intuitive interface. what's more, a simple online-streaming function lets you share gameplay live - so people can watch as you play!
r9290-dc2oc-4gd5 with all these eye-catching features now offers users all over the world a chance to experience a stunning gaming environment!
specification:-
- gpu: hawaii pro
- litecoin hash rate: 800-950
- stream processors: 2560
- rops: 64
- core speed: 1000mhz
- memory speed: 5040mhz
- memory interface: 512-bit
- memory capacity: 4096mb gddr5
- pci-express x16 lane required
- 600w or greater psu required
- power connectors: 8-pin + 6-pin required
- display outputs: 2x dual link dvi, 1x hdmi, 1x displayport
- warranty: 3yr
was [£239.99] inc. vat
only £227.99 inc vat.
order now
asus radeon r9 290x directcu ii oc 4096mb gddr5 pci-express graphics card @ £275.99 inc vat
the new card benefits from exclusive asus gpu tweak, an easy-to-use tuning tool for instant performance boosts, 4gb of super-fast gddr5 memory for the best gaming experience at the highest resolutions, and incorporates amd eyefinity and trueaudio technologies to enable expansive multi-display setups and bring in-game audio to life with more accurate environmental sounds.
the new asus r9 290x has a unique advantage in the shape of gpu tweak, an exclusive asus tool that helps users to squeeze every last drop of performance out of the radeon r9 290x gpu. this includes the ability to control finely gpu and video-memory clock speeds and voltages, cooling-fan speeds and power-consumption thresholds - so overclocking is both made easy and can be carried out with high confidence.
r9 290x is equipped with 4gb of high-speed gddr5 memory, allowing gamers to push their favorite titles much further by upping in-game visuals to maximum resolutions. the new card also includes amd eyefinity technology to broaden the gaming landscape, so gamers can expand the playing field across up to six independent displays, via displayport or dvi.
specification:-
- gpu: hawaii xt
- litecoin hash rate: 850-1000
- stream processors: 2816
- rops: 64
- core speed: 1050mhz
- memory speed: 5400mhz
- warranty: 3yr
was [£299.99] inc. vat
only £275.99 inc vat.
order now
sapphire radeon r9 290 tri-x oc 4096mb gddr5 pci-express graphics card (11227-00-40g) @ £229.99 inc vat
amd radeon r9 290 is a new graphics card powered by the latest amd radeon™ r9 290 graphics-processing unit (gpu). 4gb of super-fast gddr5 memory for the best gaming experience at the highest resolutions including 4k and incorporates amd eyefinity and trueaudio technologies to enable expansive multi-display setups and more accurate environmental sounds. r9 290 also includes support for both directx® 11.2 and amd's new mantle application programming interface (api) for great handling of even the most-demanding pc games.
specification:
- radeon r9 290</b> <br />
- gpu: hawaii pro <br />
- litecoin hash rate: 800-950 <br />
- stream processors: 2560 <br />
- core speed: 1000mhz <br />
- memory speed: 5200mhz <br />
- memory interface: 512-bit <br />
- memory capacity: 4096mb gddr5 <br />
- pci-express x16 lane required <br />
- 600w or greater psu required <br />
- power connectors: 8-pin + 6-pin required <br />
- display outputs: 2x dual link dvi, 1x hdmi, 1x displayport <br />
- warranty: 2yr
only £229.99 inc vat.
order now
sapphire radeon r9 290 vapor-x oc 4096mb gddr5 pci-express graphics card (11227-04-40g) @ £239.99 inc vat
sapphires 290 vapor-x is the fastest 290 on the market with a core clock of 1050mhz but even more impressive is the 5600mhz memory clock and with 4gb of ram making this card perfect for 4k resolution and latest games such as titanfall, diablo 3 etc.
the vapor-x cooler is simply the best cooler available full stop on any 290 card, it operates in near silence but has incredibly powerful cooling ability making this a great card for both gamers and overclockers.
specification:-
- radeon r9 290
- gpu: hawaii pro
- core speed: 1030mhz
- memory speed: 5600mhz
- power connectors: 2x 8-pin required
- warranty: 2yr
- kitguru review: http://www.kitguru.net/components/g...280x-vapor-x-oc-and-r9-290-vapor-x-oc-review/
was [£249.95] inc. vat
only £239.99 inc vat.
order now
sapphire radeon r9 290x vapor-x 4096mb gddr5 pci-express graphics card (11226-10-40g) @ £289.99 inc vat
the sapphire r9 290x vapor-x oc features several of the company’s industry-leading technologies and a factory overclock to deliver best in class performance with very low noise.
based on the award-winning graphics core next (gcn) architecture from amd with 2816 stream processors, the sapphire r9 290x vapor-x is an overclocked edition which boasts 4gb of the latest gddr5 memory running at 1410 mhz (5.64gb/s effective) and high speed engine clocks of 1080mhz.
sapphire’s innovative vapor-x cooling technology allows products to run not only cooler but also much quieter. a vapor-x product means a virtually silent gaming experience and more headroom to explore performance tweaking!
choke is an important component of the graphics card. by working with the component engineer, sapphire’s patent pending choke is 10% cooler and offers 25% more power efficiency than a normal choke. the graphics card will be more reliable and save energy.
improved reliability and better overclocking are possible by using only high-polymer, aluminum capacitors which posses far superior characteristics than regular aluminum capacitor for a longer product life. when operational temperatures drop by 20°c, the product life span is extended by a factor of ten, when the operational temperature increases by 20°c, the product life span only decreases by 10%.
along the edge of the card the pcb is extended and one of the copper layers left exposed. an additional heatsink mounted directly to this copper layer allows heat absorbed into the pcb from the gpu and other components to be transferred to the heatsink and cooled by the airflow. this feature alone can reduce core temperature by 2 degree c.
specification:-
- gpu: hawaii xt
- rops: 64
- core speed: 1030mhz >
- memory speed: 5300mhz
- warranty: 2yr
only £289.99 inc vat.
order now
kfa2 geforce gtx 980 soc gamer 4096mb gddr5 pci-express graphics card (98nqh6dnc7vz) @ £399.95 inc vat
the new nvidia geforce gtx 980/970 is powered by the next generation nvidia maxwell architecture, giving you incredible performance, unmatched power efficiency, and cutting-edge features.
maxwell is the most advanced gpu architecture ever made, designed to be the engine of next generation gaming. inspired by light, it was designed to solve some of the most complex lighting and graphics challenges in visual computing. for the first time, gaming gpu's can dynamically render indirect light using the new vxgi (voxel global illumination technology). scenes are significantly more lifelike as light interacts more realistically in the game environment.
the gtx 980 is the worlds fastest gpu and the gtx 970 offers the most advanced performance in its class. each delivers 2x the performance of previous-generation card, bringing new gaming experiences to virtual reality, and ultra resolution 4k displays.
enable the detail of 4k monitors, on a 1080p display. dsr produces smoother images by rendering a game at a high resolution, then downscaling it to the native resolution of the display using advanced filtering.
geforce gtx 980 and 970 cards support tear-free, super-fast nvidia g-sync monitor display technology including 4k. together, these technologies provide the most immersive and competitive gaming experiences possible.
features:-
- voxel global illumination technology (vxgi)
- nvidia® super resolution technology
- nvidia® gameworks technology
- nvidia® gamestream technology
- nvidia® txaa technology
- nvidia gpu boost 2.0
- nvidia physx® technology
- nvidia fxaa technology
- nvidia adaptive vertical sync
- nvidia surround
- support for four concurrent displays including: two dual-link dvi, hdmi and displayport 1.2
- microsoft directx 12
- nvidia® 3d vision® ready
- nvidia sli® ready technology
- nvidia cuda® technology
- pci express 3.0 support
- opengl 4.4 support
- opencl support
- nvidia shield ready
- nvidia g-sync ready
specification:-
- advanced ir3595 digital pwm
- multi-layer ceramic capacitors (helps reduce coil whine)
- geforce gtx 980
- gpu: geforce gtx 980 (gm204)
- process: 28nm
- core base clock: 1228mhz
- core boost clock: 1329mhz
- memory clock: 7010mhz
- memory size: 4096mb gddr5
- bus type: pci express 3.0
- memory bus: 256-bit
- cuda cores: 2048
- directx 12: yes
- dvi port: 1x dual-link dvi, 3x displayport & 1x hdmi
- displayport: yes
- hdcp: yes
- hdmi: yes
- power: 2x 8-pin
- 500w psu required
- 165w tdp
- review 1: http://www.guru3d.com/articles-pages/galax-geforce-gtx-980-soc-review,1.html
- Review 2: http://hexus.net/tech/reviews/graphics/76361-galax-geforce-gtx-980-soc/
- Warranty: 2yr
Was [£419.99] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
AOC U3477PQU 34" WideScreen Super-Wide LED Monitor @ £575.99 inc VAT
The UltraWide 21:9 aspect ratio makes movies and games more immersive than ever. Need to get some work done, too? All of that UltraWide real estate makes it easy to view multiple documents at the same time, so you don't need to flip back and forth between them.
The 3440X1440 UltraWide QHD display offers amazingly sharp picture quality. Its pixel area is about 1.8 times larger than an UltraWide Full HD 21:9 monitor, and about 2.4 times larger than a Full HD 16:9 monitor. It provides an efficient environment in using Microsoft Office programs showing 47 columns and 63 rows in excel.
sRGB is the standard color space of ideal color reproduction. So, with over 99% coverage of the sRGB spectrum, this LG monitor is a great solution for professional photographers, graphic designers or anyone looking for highly accurate color.
Multitasking doesn't have to mean shuffling back and forth between windows*. With a single click, the 4-Screen Split feature divides the screen into as many as four customizable segments, two-by-two. Now you can see four different windows at the same time.
The Dual Linkup feature allows two compatible portable devices--such as a computer, camera, phone, or Blu-ray player--to be connected to the monitor, and both can be viewed on the same screen simultaneously.
The DisplayPort digital video interface is used to connect a high-performance video source to a high-resolution monitor. Thanks to its sophisticated design, a DisplayPort cable can also be used to carry audio, USB signals and other data as well.
AOC’s LED backlighting delivers exceptional brightness and amazing image clarity. You'll see richer colors and deeper blacks too, and LEDs offer greater energy efficiency compared to conventional LCD monitors.
IPS (In-Plane Switching) technology enhances thA dynamic contrast ratio of 5,000,000:1 is your assurance of strong video performance, with deep blacks, bright whites and pleasing colors.e performance of liquid crystal displays. Response times are shortened, color reproduction is improved, and users can now view the screen at virtually any angle.
Specification:-
- Screen Size Class (diagonal): 34"
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Response: 5ms
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 320 cd/m2
- Contrast Ratio(Original): 1000:1
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Connectivity: 2x HDMI, 1x DisplayPort, 1x DVI-D, 1x Analogue
- Speakers: 2x 3W Stereo
- USB 3.0 Hub
- Height adjustment: 130mm
- Pivot & Swivel function
- VESA: 100x100mm
- Dimensions: Product with stand (WxHxD): 828 x 624.5 x 229.2 mm
- Warranty: 3yr (On-Site with AOC - 0808 234 3510)
Was [£599.99] Inc. VAT
Only £575.99 inc VAT.
ORDER NOW
LG Flatron 29UB55-P 29" WideScreen Super-Wide LED Monitor @ £239.99 inc VAT
The 21:9 ratio is the perfect professional fit for software engineers, video / sound editors, and graphic designers. Imagine 2 conventional high quality monitors attached for multi-tasking, but their screens connect and extend seamlessly. Now you can use a program with long-range panoramic view in full length, without any bezel in the middle or dragging cursors. No longer divide your focus into separate monitors, the 29UB55 is the perfect companion for your profession.
Like other smart devices, the 29UB55's Pivot & Height Adjustable feature allows you to simply rotate the screen to fit vertically long images or files. When pivoting, you can easily adjust its height too. Leave dragging and scrolling behind. Let the monitor adjust to your images and needs.
Connect two devices to a single monitor with Dual Link-up that allows an HDMI + HDMI link. Now you and your colleague can simply bring each other's devices and connect to a single monitor to share and compare information. Freely show and control your screen while watching your partner doing the same on the opposite side of the monitor. Don't bother installing annoying projectors in your small room or worry when your conference room is occupied, the 29UB55 is here for you.
With its wide screen ratio, now you can open 4 programs on a single screen to see your information in a single glance while working. The size of sub screens is user-controlled. The 29UB65 is compatible with Mac® and not only provides convenience but also productivity in a single click, you can split your screen into 2 to 4 subscreens.
Reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for as long as you would like to.
As LG IPS Monitor features consistency and less changes in colour temperature, it offers a colour impression identical to that of the original image. You can enjoy lifelike picture picture quality without any colour shift whether you are standing or lying down. It allows you to enjoy any content, such as action movies, web surfing and RPG games for a long time in comfort.
Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction.
The joystick is a harmony of accurate menu controls and analogue sensitivity. With the fun control of a conventional joystick, its modern technology and design allow for simple control with a pleasant touch. In addition, intuitive UI with no overlapping is easier to understand and select menus.
Specification:-
- Screen size (inches): 29"
- Panel Type: IPS
- Resolution: 2560*1080
- Brightness (cd/m2): 250
- Contrast Ratio: 50000000:1
- Viewing Angle (°): 178/178
- Colour Depth (Num of Colours): 16.7M (6-Bit +FRC)
- Colour Gamut: sRGB 100%
- Surface Treatment: Hard Coating (3H), Anti-Glare
- Connectivity: 1x DVI-D, 2x HDMI, 1x DisplayPort
- Speakers: 2x 5W
- Height adjust stand
- Warranty: 2yr (On-Site with LG - 0344 847 5454)
Was [£299.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Acer 4k2k CB280HK 28" Gaming Widescreen LED Monitor - Black @ £299.99 inc VAT
The Acer CB0 Series monitors provide an outstanding visual experience via high resolution and wide viewing angles. These monitors are packed with Acer technologies to deliver superior comfort while you get the job done. Plus, as an Acer EcoDisplay they are designed to save power and costs.
Specification:
- Flicker-less Technology
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Colurs: 16.7M
- Bits: 8 bits+HiFRC
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort 1.2 (60Hz), 1x DVI and 1x HDMI
- VESA: 100x100mm
- Speakers: Yes
- Warranty: 2yr (On-Site with Acer - 0371 760 1000)
Was [£349.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Acer Predator 4k2k XB280HK 28" G-Sync Gaming Widescreen LED Monitor - Black/Red @ £499.99 inc VAT
nonl2br
<p>
Acer XB280HK gaming monitor as the world’s first 4k2k display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
</p>
<p>
The Acer XB280HK is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 28-inch LED backlit display with 4k2k Ultra HD (3840 x 2160 pixels) that’s four times the resolution of 1080p Full HD, and presents stunning high quality images for outstanding visual enjoyment.
</p>
<p>
With a GeForce® GTX™-powered PC, NVIDIA® G-SYNC™ display technology synchronizes the display’s refresh rates to the GPU to eliminate screen tearing and minimize display stutter and input lag to deliver smoother, faster, more breathtaking gaming experiences. Scenes appear instantly, objects look sharper and more vibrant, and gameplay is more fluid and responsive providing gamers with significant performance advantages.
</p>
<p>
The Acer XB280HK features 170/170 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
</p>
<p>
The Acer XB280HK monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
</p>
<p>
This eco-friendly monitor features a mercury- and arsenic-free panel, LED backlighting for reduced power consumption, and is ENERGY STAR®(1) qualified.
</p>
<center>
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/4qyrT7l0nwg?version=3&amp;hl=en_GB&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/4qyrT7l0nwg?version=3&amp;hl=en_GB&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="true"></embed></object>
</center>
<br><br>
<p>
<h1>Features:</h1>
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.<br>
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.<br>
- ComfyView technology – the non-glare panel reduces reflection from light source.
</p>
<p>
<h1>Specification:</h1>
- G-Sync Technology<br>
- Flicker-less Technology<br>
- Height Adjust stand with tilt, swivel and pivot<br>
- Display Screen Size: 28" (70.8cm)<br>
- Aspect ratio: 16:9<br>
- Panel Type: TN<br>
- Brightness: 300cd/m2<br>
- Contrast Ratio: 1000:1 (Typ)<br>
- Dynamic Contrast Ratio: 10,000,000<br>
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)<br>
- Response Time: 1ms (GTG)<br>
- Colurs: 16.7M<br>
- Bits: 8 bits+HiFRC<br>
- Viewing Angle (H / V ): 170 ° / 160 °<br>
- Connectivity: 1x DisplayPort 1.2 (60Hz)<br>
- USB Hub 3.0: Yes (1up, 4down)<br>
- VESA: 100x100mm<br>
- Speakers: No<br>
</p>
Was [£569.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
AOC U2868PQU 28" 4K 60Hz 1MS Gaming Widescreen LED Monitor - Black @ £329.99 inc VAT
The U2868PQU from AOC is designed for gamers as it features a rapid 1ms response TN panel with a staggering resolution of 3840x2160. Your games will never have looked so good, but bear in mind to play the latest games at 4k resolutions you will need a minimum of 780Ti or 290X and ideally a pair running crossfire/SLI to play at 4k with maximum details with 60fps or more. This monitor is also 60Hz at 3840x2160 when connected via DisplayPort.
Featuring great connectivity with VGA, DVI, HDMI and DisplayPorts along with a full height adjust, pivot and swivel stand with VESA 100x100 support. Making the AOC U2868PQU ideal for eye-finity/surround setups. The monitors also includes stereo speakers and USB Hub as well.
Specification:-
- Size with stand (W x H x D ) : 658.9x560.6x245 (mm)
- Without stand (W x H x D ): 658.9x395.8x50 (mm)
- Panel Type: TN
- Dynamic Contrast Ratio: 80,000,000
- Connectivity: 1x HDMI, 1x DisplayPort, 1x DVI, 1x VGA, 1x USB Hub
- Stand: Height adjust, pivot & Swivel
- USB Hub: Yes
- Speakers: Yes
Was [£389.99] Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
Samsung U28D590 28" 4K 60Hz 1ms Gaming Widescreen LED Monitor - Black @ £379.99 inc VAT
nonl2br
<p align="left">
OcUK will be the first in the UK to get official UK version of this monitor by upto nearly a month. We are expecting our delivery the last week of May. None of our competitors will get stock until mid-end of June as we have an exclusive arrangement with Samsung. This monitor is one of the best 4k displays available and OcUK will have it before any competitor by upto at least two weeks. Pre-order with confidence from ourselves on this stunning Samsung U28D590 28" 4k 60Hz 1ms Gaming Widescreen LED Monitor.
</p>
<p align="left">
Samsung U28D590 the Main feature of novelty is the resolution 4K (3840×2160), exceeding Full HD (1920×1080) four times. Natural color reproduction with soft color transitions is achieved, in particular, by playlist 1 billion colors. Response time is 1 MS, which perfectly fit to play the game content. Also amongst the peculiarities of the availability of an updated Picture-in-Picture (PIP 2.0). With its help it is possible to reproduce a picture of a small window in the original resolution up to Full HD (1920×1080 pixels) as the main picture is reproduced in UHD. In addition, when playing content small-resolution, innovative function UHD upscale will improve the clarity and quality of the image to the maximum possible resolution of 4K (3840×2160).
</p>
<p align="left">
The novelty provides connectivity, audio-video devices: include 2 HDMI port and one interface connector Display Port. It is worth noting that the monitor can be connected at once two PC and play back content from both devices without any loss of quality, resolution images with each PC will 1920×2160. This monitor can be easily connected Xbox or PlayStation 4 via the HDMI.
</p>
<p align="center">
<object width="640" height="360"><param name="movie" value="//www.youtube.com/v/X5YXWqhL9ik?version=3&amp;hl=en_GB&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/X5YXWqhL9ik?version=3&amp;hl=en_GB&amp;rel=0" type="application/x-shockwave-flash" width="640" height="360" allowscriptaccess="always" allowfullscreen="true"></embed></object>
</p>
<br /><br />
<p align="left">
- Size with stand (W x H x D ) : 660.9x486.3x169.4 (mm)<br />
- Without stand (W x H x D ): 660.9x410.0x64.7 (mm)<br />
- Packaging (W x H x D ): 794x452x109 (mm)<br />
- Display Screen Size: 28" (70.8cm)<br />
- Aspect ratio: 16:9<br />
- Panel Type: TN<br />
- Brightness: 300cd/m2<br />
- Contrast Ratio: 1000:1 (Typ)<br />
- Dynamic Contrast Ratio: 10,000,000<br />
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)<br />
- Response Time: 1ms (GTG)<br />
- Color Support : 1B<br />
- Viewing Angle (H / V ): 170 ° / 160 °<br />
- Connectivity: 2x HDMI (30Hz), 1x DisplayPort (60Hz)<br />
- USB Hub: NO<br />
- Speakers: NO<br />
- Warranty: 2yr (On-Site with Samsung - 0330 726 7864)
Was [£429.95] Inc. VAT
Only £379.99 inc VAT.
ORDER NOW
Asus VS229HA 22" Widescreen MVA LED Monitor - Black @ £89.99 inc VAT
Delicate touches make a monitor truly great, VS229HA Full HD LED monitor, with 80,000,000:1 high contrast ratio and full HDMI, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port.
VS229HA adopts 178°(H) / 178°(V) ultra wide viewing angle panel that eliminates color shift on your screen no matter where and how you look at it. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
Specifications:-
- Screen Size: 21.5"
- Screen Type: VA
- Backlight: LED
- Aspect Ratio: 16:9
- Recommend Resolution: 1920 x 1080
- Screen Features: Full HD
- Colours: 16.7 Million
- Pixel Pitch: 0.248mm
- Horizontal Frequency Range: 30kHz - 80kHz
- Vertical Frequency Range: 56Hz - 76Hz
- Response Time: 5ms (GTG)
- Dynamic Contrast Ratio: 80,000,000:1
- Brightness: 250 cd/m²
- Horizontal Viewing Angle: 178°
- Vertical Viewing Angle: 178°
- Tilt Angle: -5°/20°
- VGA Port(s): 1
- DVI Port(s): 1
- HDMI Port(s): 1
- Warranty: 3yr (On-Site with Asus - 01442 265 548)
Was [£99.95] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
TeamGroup Elite 16GB (4x4GB) DDR4 PC4-19200C16 2400MHz Quad Channel Kit - Black (TPKD416GM2400HC16QC01) @ £149.99 inc VAT
TeamGroup Elite DDR4 offers great value and great performance with superb looks with all black PCB and heatspreader design,.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 16-16-16-36
- Tested Voltage: 1.2V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Warranty: Lifetime
Was [£179.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
We are un-rivalled when it comes to memory prices, I mean 2666MHz 16GB kits, our competitors struggle to do that on 1600MHz kits, LOSERS! :D
Prices on the other items should also be pretty much the best out there, prices go back up tomorrow at around 9am, do not miss out! :)
The picture for the "Asus Radeon R9 290 DirectCU II OC 4096MB GDDR5 PCI-Express Graphics Card @ £227.99 inc VAT" is a bit misleading, people might think they are going to get a free pair of headphones too!
Some kind of issue with the forum, the webshop displays no such image. :)
Ah. Does anyone know what time the OcUK Mega Mat XXL goes on "this week only" tomorrow ?
Only ask as I would like to buy the TeamGroup Xtreem LV 16GB Ram & The XLL mat at the discounted price.
Anyone find a decent review for the LG 29Ub55?
Have that monitor, great for film, great for gaming imo. No input lag, no ghosting. added bonus is that l can run my Windows pc on one half of the monitor and my linux rig on the other (either in zoom or orig ratio).
Also comes with a handy inbuilt usb hub(need your own usb cable).
