"Integrated graphics device not found" 3570k iGPU
  • Thread starter Thread starter MrH
  • Start date Start date
MrH
MrH
16 Jan 2010
UK
I'm having a problem installing Lucid Virtu MVP, when I try and install the software it says "Integrated graphics device not found". I have enabled the iGPU in the bios so I'm not sure what's wrong.
Asus p8z77-v pro
3570k
latest bios
Asus p8z77-v pro
3570k
latest bios
I thought MVP was to increase framerates on dedicated GPUs installed to the system not for the IGP alone. The old lucid virtu software switched between the IGP and GPU as needed, you should get this feature from MVP too.
DO you have a dedicated GPU or just the IGP?
