Suffice to say I would take what has been written on Toms and others with a massive sack of salt. Based on their article I've been worrying myself silly about shifting heat and it has been exactly the opposite. My XMP based overclock has set a 4.2Ghz base and my typical have this thing running about 20c cooler than my 3930K for a similar overclock. I need to do more benching but this thing just isn't getting hot at all, and the TDP hasn't been anything close to the fabled 240w that they claimed they were seeing. I thought it didn't stack up at the time that I read that, and my actual experience is indicating that my gut instinct was correct. Either that article is a crock, or they were reviewing an engineering sample and perhaps my OEM lower tray priced unit is from a more recent batch - because it's freakin amazing! It's early days and maybe I've just not hit a workload that is really going to push it. I've got some AVX based workloads I can throw at it (which is another reason why I didn't wait for threadripper) and it might be that I'll start seeing something different then.
I think TTL did say under normal usage you won't see those insane power draws and temperatures. To get them you need to make specific changes in the BIOS to the safety features, be running the most demanding version of Prime95, and at 4.8GHz+ on 10 cores.
Personally I've got my 7820X running at 1.0V. Maybe I'll overclock it in the future. I upgraded from a 3770K. Having to buy another 16GB DDR4 kit for quad channel is what took the price higher than I had planned. And then I decided "bugger it" and bought a 500GB PCI-E NVMe SSD as well
