1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Is loss of power an MOT fail?
Discussion in 'Motors' started by jsmoke, May 8, 2019.
  1. Jez
    Caporegime
    This is totally illogical, think about it :p
    I would be rather annoyed if i had paid for a test and they did do that, for the fee i would expect a complete report so that i know where i stand with the vehicle in terms of repair. If a tester abandoned the test at first clear failure then no-one would ever know the total damage to get through!
  2. Firestar_3x
    Caporegime
    Seems odd, you have paid for the test, you clearly want to know everything which is wrong, not just the first item............................
    If you look on the MOT test history site its easy to find cars with whole lists of issues raised on one test.
    *As above, hes making stuff up again.
  3. Nasher
    Capodecina
    Normally you get a free re-test.
  4. Lopéz
    Man of Honour
    Think carefully about what you are saying.
  5. Jez
    Caporegime
    Yes but you always get (and would expect) a full rundown, so that for the retest you present in passable state. If they abandoned after each fail item you would be going round in circles test after test with some old vehicles.
  6. Orionaut
    As an aside, I have always podererd how often the following scenario occurs.
    MOT fail due to large windscreen crack in designated area.
    On way back for retest, after new windscreen fitted, stone causes large crack in designated are resulting in a second fail.
    Statistically this must have happened to somebody.
    Indeed, statistically, this must have happened to some poor SOB twice, or even three times or more, in a row!
    :p
  7. Jez
    Caporegime
    You could apply that to any MOT noteworthy damage happening on the way to a test :)
  8. Orionaut
    Yes, but windscreens in particular, are a random failure event.
    Even the possibility of bulb fails can be mitigated by fitting new ones a month or so before the test is due. (Not immediatly before the test, new compoanants can fail too, but after a month or so, the replacements should be considererd reliable.)
    But there is little that you can do to mitigate the possibility of a stone on the windscreen
  9. Rroff
    Man of Honour
    It is usually contrasted against things that you might get away with versus things that will never get through an MOT unless the tester is blind.
  10. Mercenary Keyboard Warrior
    Sgarrista
    Its Nasher, my default position if its something I dont know to be true, is to assume its the opposite to what he posts. I haven't been let down yet ;)
    In fact I take his Brexit supporting position as a guarantee its the wrong option :)
  11. Nasher
    Capodecina
    Mercenary Keyboard Warrior is not a ****.
  12. Rich1988
    only if it relates to a safety feature as said above. one of my cars has an aircon warning light on the dash because i've removed the air con from the car. it's been through the mot on the new rules no issues.
  13. The Craig
    One of mine was identified as leaking minorly as an advisory on my MOT this april.
    A month later i brought it in as it was making a loud noise. Ended up getting 3 injectors removed/cleaned up/seals replaced for £190 from my good local independent which seems good to me!
    I drive a 1.6diesel suzuki sx4 and guess labour cost depends on the car/engine accessibility.
