No because there is no need, the change is only updated cpu compatibility.
The site usually only says that, but sometimes there are also bug fixes too, so I would try updating the BIOS first.
.The nforce 610i chipset is PCIE 2.0 so that's not the issue.
Edit - Ok Ignore that, it may well need a bios update as the onboard nvidia graphics only uses pcie 1.1 so it is possible that the initial bios only supports 1.1. The chipset certainly supports 2.0 though.
Yep I will, I know a lot of people on here would have said 470 or nothing, but I value my electricity bill, for all of you who don`t know 150w 24/7 will add up to about £120 a year.I still have a lot of upgrades to do till I am happy, but a small budget is limiting me, I am still on lga 775 for god sakes, and using stock cooling, It looks like it might be a expensive christmas.
150W 24/7 ?? you musn't get much sleep then ?
that is only under full load, at idle (ie not in a game) I think they are about 25W difference ....
