just a tip if there fitting a smart meter may want to ask them about a isolator between the meter and the cu. they may already be fitting it but i would check then if any work needs to be carried out in the future your electrician can isolate the electrics without the main fuse needing to be pulled ( i know only dno allowed to remove it, but some electricians will risk it).
reason i suggest this is we are with eon and just before christmas we wanted our cu changed and the electrician wanted a isolator fitting...shouldnt cost that much but supplier has to fit it...cost us 98pounds +vat onto bill but heyho had to be done.
by the way we have 2 consumer units and the call centre wanted to charge us twice.. i told them that i only wanted the day unit isolating and the night unit could stay (by this stage was a bit annoyed with there attitude) guy comes out..hey presto fits a double unit same money,,
Thanks, I'll mention it to them when they come out.
As other have said, the garage wiring looks highly suspect. I wouldn't bank on being able to reuse any of it.
If you've got an electrician in I'd also look at getting the kitchen socket circuit breaker to changed from an MCB to an RCBO. If the board is still supported this should be an easy job and will give you a substantial safety upgrade.
We will most likely have a full rewire when we renovate (few walls to knock down) and convert the attic, but that won't be for a year or so. I was mainly wondering if I could hook the garage up for immediate use with not a lot of work, but it seems to be not the case.
Shudders, is that an asbestos roof?
It is, well spotted. It was flagged in our Building Survey and we got the asking price dropped considerably to cover the work to remove it, same goes for the rain water downpipes. All safe as long as we don't mess with any of it, so no real rush to get it removed but it will be sorted at some point.
I presume you tried plugging something into the socket right?
(Not your tongue/fork/screwdriver etc).
I didn't need to, as there is a hanging wire where the light fixture was I figured it can't be hot.
Thanks all for the replies, quite a lot of knowledge about electrical to say it's just a computer forum
