Just wondering if anyone can help me out with this, because i'm sure there's something blindingly obvious that i'm not seeing.
The issue is that when i'm screwing the backplate down to the motherboard using the standoffs, it isn't tight. It seems as though it would require a spacer or washers of some sort but there aren't any in the box, nor are they mentioned in the manual. I mounted it exactly as it said in the manual, yet it is still very loose.
The reason this came to my attention was, I noticed ridiculously high temps in HW monitor during a light stress test, over 100 degrees. So this lead me to believe that there is little to no mounting pressure on the cpu cooler, which seemed to be the case upon further investigation.
I have since fitted my old hyper 212 back on for the time being, until I can fix this issue.
