It's hot, hot, hot! Cooler deal for you.
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys.
Cool your CPU with this great mid-range CPU cooler from Akasa, now at a much better price, exclusive to OcUK :)
Akasa AK-CC4005SP01 Venom Nano CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) @ £21.98 inc VAT
The highly effective 10cm fan in killer Viper yellow delivers vast amounts of airflow for top notch cooling. The PWM function ensures quiet operation during normal system use and performance cooling under load. Three nickel plated heatpipes with direct CPU contact provide rapid heat transfer from CPU to 50 high grade aluminium fins. Anti-vibration rubber fan mounting pins help to eliminate a lot of fan noise. New design akasa (patented) Easy Select Clip with Intel reference push-pin retention is used for no-hassle mounting on Intel LGA775, LGA1156 and LGA1366 platforms - no backplate is needed. AMD Sockets AM2, AM2+ and AM3 are catered for with a spring-loaded screw mounting for safe and reliable attachment. Performance thermal compound is supplied.
- Low noise 10cm PWM fan in killer Viper yellow
- Three nickel plated heatpipes with direct CPU contact
- Quick installation with akasa Easy Select Clip
- Anti-vibration rubber fan mounts
- Aluminium fins, copper heatpipes
- 154(H) x 107(W) x 80(D) mm
- 600 – 2500 RPM (PWM controlled)
- Max Airflow: 67.38 CFM
- Noise Level: 14 – 28 dB(A)
- 4pin PWM
Was £29.99 Inc. VAT
Only £21.98 inc VAT.
ORDER NOW
How do these compare to the arctic cooling freezer 7 pro for performance? Am interested in one for a upcoming build!
