Anyone else venting a portable AC out a sealed window, I just want to check if you're adhering to the exact exhaust pipe angle they recommend?
Mine says the duct hose shouldn't exceed 30 degrees of bend which is ridiculous as a short unit on wheels needs about 45 degrees on the duct hose to get to even the lowest UK windows.
It's cooling just fine with a sealed window kit, hot air blasting out the sealed window as I can test it from an adjoining window, it's nicely sealed with ice cool air blasting out the louvres. It's only that I read the manual from cover to cover that I even noticed the 30 degree stipulation which seems ridiculously strict.
I can't see an issue using at 45 degree or higher this way as hot air rises through a short and very wide ducting, I'm not seeing any issues this way with hot air flow escape or overstraining the system.
Any thoughts from portable users appreciated.
