Ive got a 2nd hand water kit.. will you check it over..
25 Jan 2006
Gateshead, Newcastle
Before you all start on me telling me this is a pile of **** i have gotten it because it was cheap and should be silent.
I KNOW it isnt going to keep my temps much cooler than my current cooling BUT im hoping it will give me silence.
okay i have a few pics and i have rust, for starters i think.. so i need some advice.. how to i get rid of it.. and if i cant should i just chuck it in the bin?
Pics.
So.. advice? ideas?
Thanks for looking
StevenG
Oh dear - galvanic corrosion! Tomatoe sauce to clean it up, make it look pretty, then sell it and deny all knowledege of ever owning Thermaltack!
short-out pins 14 and 15 on the power supply main power connector, and plug-in the power cord This may not be the best thing to repeatedly do to an ATX power supply (it can damage it).
You have a great pc system - the wc system will let it down. Save and buy a proper wc setup if that is your real intention.
think i have THE biggest E-Penis EVER lol.. need to get some fluid to fill it up with first.. anyway..
will the TIM Clean stuff that you use for heatsinks get rid fo the rust because thats just citric acid and some other crap
Coca cola, not the cheap stuff the original. Drop the block in there for like 10 minutes and it should come up looking like new. For the connections use some metal polish (autosol or peek).
taddaaaaaaaa
So.. if im using di-ionised water.. do i need to put any other addetives into it??
well to be honest it doesnt look that much difference.. the clean bits are shiny and the rusty bits are a little faded but thats about it..
