Hello Gareth
Your subwoofer is on the test bench, the engineer tests the subwoofer with a signal generator so that he can sweep the entire subwoofers frequency band and pin point any frequency that is causing a problem. The engineer cannot replicate the farting noise, so the subwoofer will be left on soak test today. If we cannot find any problems we will fit a new loudspeaker and amplifier and return the subwoofer to you.
update
now i'm confused. first thing,, what is soak test?, second why are they continuing testing it if they are going to fit a new loudspeaker and amplifier anyway?
Soak testing involves testing a system with a significant load extended over a significant period of time, to discover how the system behaves under sustained use.
For example, in software testing, a system may behave exactly as expected when tested for one hour. However, when it is tested for three hours, problems such as memory leaks cause the system to fail or behave randomly.
Soak tests are used primarily to check the reaction of a subject under test under a possible simulated environment for a given duration and for a given threshold. Observations made during the soak test are used to improve the characteristics of the subject under test further.
In electronics, soak testing may involve testing a system up to or above its maximum ratings for a long period of time. Some companies may soak test a product for a period of many months, while also applying external stresses such as elevated temperatures.
This falls under stress testing.
just called them today and guess what still testing. now im getting abit ***** off. last friday they said it'll only take 1 to 2 days. as it's going i won't see the sub till maybe monday.
my Yamaha 5.1 amp blow due to water damage. so im using my old cheap 5.1 amp prosoundWell it does sound like they can't find the problem, so yes they would still be testing, surely? What amp are you using?
i don't think so. because i have being using my old sub on it without issues..Can't say I've heard of them. I'm just wondering if its something on the amp causing issues with the signal the sub is receiving, rather than the sub having something wrong with it.
i got it back and they said they've fited a new loudspeaker and amplifier but im not sure if thats true because the controls was set to max. anyway it still makes that noise on certain songs..How you getting on?
the guy thinks it's a amp component that's faulty..Sounds like a lose connector. Recording on the phone is not ideal either. White noise and more white noise. Sorry to see you've had such trouble with the amp. At least you will have the comfort of knowing that once you have a fully functioning amp it will be so much better than the JBL. Furthermore, if they can't fix it they may even offer you a different model. Small companies tend to be much more concerned with customer satisfaction so perhaps you shouldn't keep second guessing and hold out for a satisfactory result. The fact you can even contact a manufacturer these days by any method is a blessing. Hello JBL? Ja. Nein. ok...
Hello Gareth
We received the subwoofer at 4.00pm yesterday, the amplifier has been repaired and is on soak test now and we will return the subwoofer today to be with you on Monday
Regards
Tom
Hello Gareth
The amplifier has short circuit protection on it and the low voltage power supply has just enough voltage to turn the amplifier on, once there is a signal to the loudspeaker a feedback circuit takes some of the signal then rectifies it then feeds this back to the low voltage supply to support it, this keeps the amplifier working. If there is a short circuit on the amplifiers output this voltage cannot be fed back and the amplifier will not work. This part of the circuit had failed, so without the support from the signal the amplifier cannot work.
The loudspeaker is not damaged as the amplifier cannot work whilst the faulty existed, Its on the test bench and it sounds fine
Regards
Tom
Hello Gareth
The short circuit part died, no short. The fault is nothing that you have done just a failed component . I would plug the mains the same way as you did before
Regards
Tom
