** JUST AINT GOT ENOUGH POWER CAPTAIN!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
No idea what kind of graphics card if any will be able to power this beast when gaming, though the point of this monitor is really for professionals not gamers, but still the image quality has to be beyond belief!!!!
Dell UltraSharp UP2715K 27" 5K Widescreen LED Monitor - Midnight Grey @ £1,799.99 inc VAT
Discover amazing 5K clarity on the highest-performance DellTM UltraSharp display, featuring over 14 million pixels, precise, accurate color and amazing acoustics from Harman Kardon® .
Pin-sharp 5120 x 2880 Ultra HD resolution: See four times the content of QHD with 11 million more pixels that create crisp images and breakthrough sharpness. Vivid, accurate and consistent color: With PremierColor, your monitor provides superb color accuracy and 99% AdobeRGB and 100% sRGB coverage. Speakers by Harman Kardon® : Two speakers rated at an impressive 16W deliver crystal-clear, highly detailed stereo sound.
Welcome to the amazing sharpness and clarity of a 5K monitor. The Dell UltraSharp 27 Ultra HD 5K Monitor – UP2715K features an astoundingly vivid 5120x2880 Ultra HD resolution. That’s a dramatic increase in screen clarity, with more than 14 million pixels — or four times the content of QHD resolution, seven times the content of Full HD displays and almost double the number of pixels in an Ultra HD 4K monitor. The result is a breakthrough visual experience that brings outstanding realism, depth and crispness to pictures and movies.
If you’re a graphics or design professional in the entertainment, film, photography or engineering field, you’ll immediately recognize the benefits of a 5K monitor with Dell PremierColor. Details this incredible allow you to view your work with a whole new level of insight.
Features:
- Consistent, accurate colors: Right out of the box, Dell PremierColor delivers factory-tuned 99% AdobeRGB and 100% sRGB coverage, impressive grayscale tracking and a color calibration factory report certifying that colors are true-to-life and accurate with an extremely small deltaE of less than 2.
- Excellent color depth and color gamut: Enjoy a large range of colors and color detail with a wide color gamut1. High-capacity 12-bit internal processing enables up to 1.07 billion colors, distinguishing low grayscale tones and enabling a tremendous level of detail, even in dark areas.
- Use the Custom Color mode to change color parameters to your exact needs. Tune and tweak onscreen colors by utilizing a wide range of color parameters such as RGBCMY saturation, RGBCMY hue, RGB gain and RGB offset.
- For even greater control and precision calibration, the UP2715K comes with a 12-bit user-accessible 3D LUT (look-up table), which is accessible via the Dell UltraSharp Color Calibration Solution software when used with the optional X-rite iDisplay Pro colorimeter2.
Specification:
- Diagonally Viewable Size: 27" (27-inch wide viewable image size) 68.5cm
- Aspect Ratio: Widescreen (16:9)
- Panel Type, Surface: In-plane switching, anti glare with hard coat 3H
- Optimal resolution: 5120 x 2880 at 60 Hz (Dual DP cable required) 3840 x 2160 at 60Hz (single DP cable required)
- Contrast Ratio: 1000: 1 (typical)
- Dynamic Contrast Ratio : Mega7
- Brightness: 350 cd/m2 (typical) / 50 cd/m2 (min)
- Response Time: 8 ms (gray to gray)
- Viewing Angle: (178° vertical / 178° horizontal)
- Color Support: Color Gamut (typical): Adobe RGB 99%, sRGB 100% 1.074 Billion colors (True 10 Bits)
- Pixel Pitch: 0.116 mm Pixel Per Inch (PPI) 218
- Backlight Technology: LED
- Display Type: Widescreen Flat Panel Display
- Display Screen Coating: Antiglare with hard-coating 3H
- Connectivity: 1 Mini DisplayPort, 2 DisplayPort (DP1, DP2), 5 USB 3.0 ports - Downstream (4 at the back, 1 with battery charging), 1 USB 3.0 port - Upstream, 1 Media Card Reader
- Warranty: 3yr
Only £1,799.99 inc VAT.
ORDER NOW
Well I suppose they figured they might as well try and flog a few of these given that the panels had already been made for the new iMac.
Alas no current Mac can actually drive this screen externally, and the pixel size means the experience in Windows would be problematic until Microsoft sort out their UHD+ support.
But the screen is amazing; it's just the support for it that's lagging behind at the moment.
I would really really really like this monitor BUT...
It is the same panel as in the iMac retina... for the same price as an iMac retina... with no computer attached to the back of it.
It's a great resolution which Apple have been able to integrate as a single panel... Dell have moved forward with dual-tile input.
The price is frankly absurd for what you get... for £1000 I would be tempted to buy one... but for this price, it's a much better deal to purchase a retina iMac :(
Problem is that iMac doesn't have the GPU to power 5K display, the base M290X is basically just an underclocked 7870 and M295X is just an R9 285.
That and you can't use it as an external display.
You sure? Previous iMacs had that ability, it was a toggle during boot iirc.
Yeah,
Currently no support for using it as a monitor... due to the custom display driver they have built to use it as a single tiled display.
I think it may be a supposed transport-stream limitation... no "external" input controllers yet capable to driving that as a single tile... even if the cable bandwidth can handle it.
Isn't the 5K iMac the exact same screen quality in terms of viewing angles and quality? If this is the case I'm tempted to purchase the 5K iMac and use it as workbench machine and have my gaming PC powering my 1440p as normal. Can anyone let me know?
