- 10 Apr 2006
- North West
Didn’t have a chance before I went away, I’m back at the weekend so I’ll see if I can then.
Gibbo
Do you have any Action Camera mounts attached to your Rollecage. If so do you have any pics?
No worries. Looking for a mount for mine.... Have found one. But it's 25 quid!
https://www.amazon.co.uk/GoPro-GRBM30-Roll-Bar-Mount/dp/B001MS6OM2
I use that and it works great on a harness bar which is same thickness as rollbar. There are cheaper copies but they don't have foam on the inside of the mount so they will scratch and vibrate on the bar.
Regarding your options for your next car, I think you would seriously regret selling this car. So scrap that option.
Where did you get the wrapping done @Gibbo ? - I’m experiencing similarities with my e38, after 18 years a few bits of trim around the windows are starting to crack and fade, I’d like to rectify this so long as it’s not too silly money wise....
The e46 is looking epic, don’t move it on, to have owned a CSL and let it go to potentially do the same with this one which arguably is amongst the best e46 M3’s out there would imo be one move you’d look back and kick yourself for.
Cheers, found them.Wrapstarz Pro mate, does all his business via social media:
https://www.facebook.com/wrapstarzprouk/
The m3 looks glorious Andy
The Vanos failed on my first M3, just after a service where they took the top off to check things up top, which was part of the service around 20K miles. Started as a rumbling but was very obvious and I wouldn't bother replacing them as a precaution on a track car frankly. If they go you'll hear them going, so get them done then if they ever go.
