1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Competitor rules
    Dismiss Notice
Just got a 7800gtx, do i plug both power cable in?
Discussion in 'Graphics Cards' started by ultim, 18 May 2006.
  1. ultim
    Hitman
    Hi
    Ive got a molex to 6pin power cable for my 7800gtx card. it has two molex cable to one 6pin adaptor. At the moment ive only plugged in one of the molex cable to my psu. Do i need both of them plugged in to my psu?
    thanks
  2. toxic
    Wise Guy
    yes
  3. ultim
    Hitman
    for some reason when i plug both in, my computer wont boot up. Will it work fine with just one plugged in?
  4. toxic
    Wise Guy
    make sure the two 3 pins connectors come from two different rails...not the same one. What PSU?
  5. ultim
    Hitman
    seasonic 420w
  6. toxic
    Wise Guy
    you could try it with one 3 pin in....it might boot...but wont get enough power when gaming. I thing you will probably gett a beep error and post...you definitely need to plug both in though.
  7. ultim
    Hitman
    im using one 3-pin plugged in atm and just had a quick blast on tomb raider, seems to be working fine.
    ill try plugging the other 3pin into a seperate rail later.
    thanks for the help
