** KARATE CHOP!!!!! NINJA's ARRIVE AT OcUK!!!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
The only stockist of white DDR4 RAM in the UK, check it out!!!
Panram Ninja-V 16GB (4x4GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit (PUD42400C154G4NJW) @ £229.99 inc VAT
Panram's winning advantage has always been the manufacturing efficiency and quality, our production base is located in Keelung, Taiwan Liudu, mass production in 2005, and constructed by intelligent manufacturing management system (Intelligent Manufacturing System).
Panram Technology since 2001, has certified through a number of international brand manufacturers of memory, system manufacturers, and to become the world's few international companies to undertake various types of modular products professional Original Equipment Manufacturing (OEM) and dedicated design foundry (ODM) services company.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 15-15-15-35
- Tested Voltage: 1.25V-1.45V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
- Warranty: Lifetime
Only £229.99 inc VAT.
ORDER NOW
Panram Ninja-V 32GB (4x8GB) DDR4 PC4-19200C15 2400MHz Quad Channel Kit (PUD42400C158G4NJW) @ £419.99 inc VAT
Specification:-
- Capacity: 32GB (8GBx4)
- SPD Voltage: 1.2V
Only £419.99 inc VAT.
ORDER NOW
Panram Ninja-V 16GB (4x4GB) DDR4 PC4-21000C15 3000MHz Quad Channel Kit (PUD43000C154G4NJW) @ £359.99 inc VAT
Specification:-
- Tested Speed: DDR4-3000 MHz (PC4-21000)
- Tested Latency: 15-17-17-35
- SPD Voltage: 1.2V
Only £359.99 inc VAT.
ORDER NOW
Panram Ninja-V 16GB (4x4GB) DDR4 PC4-21300C16 3200MHz Quad Channel Kit (PUD43200C164G4NJW) @ £419.99 inc VAT
Specification:-
- Tested Speed: DDR4-3200 MHz (PC4-21300)
- Tested Latency: 16-18-18-35
- SPD Voltage: 1.2V
ORDER NOW
I'm not sure a Ninja would be particularly effective at performing a karate chop given their technically trained in Ninjustu.
I'm sure one martial art can be transferred to another, especially when its a single simple chop. I'm sure a Ninjustu expert would be more than capable of doing a single Karate Chop.
