I don't need to insert a key or to start the engine. I don't have keyless entry though. Pressing a button to open the car really isn't that much hassle.You dont need to insert a key to open the door or start the engine.
Jeez, dim or what ?
Jeez, dim or what ?
Yea except much of what they put in modern cars is done just because it's cheaper. A high quality, physical lock and coded key, which will last the life of the car costs a lot more than a simple RFID device.
Most people will notice a shoddy key and lock. They won't notice shoddy (or non existent) encryption on a wireless device unless they are skilled IT security analysts.
You really really MUST stop making up 'facts' to fit your anti-manufacturer agenda.
You’re out on an adventure and an alert is received that atmospheric conditions are about to fry your electronics. So, unless you have paid for the U.S. Government TEMPEST edition of your electronics, it’s a good thing you have your EDC EMP hank to shield your devices. Whether the alerts are from solar radiation, nuclear detonation or static discharges, you’ll need something to protect your electronics. The EMP hank is made of your choice of various colors and designs and has a Nickle/Copper backing that is patterned as a Faraday cage. In 1836, Michael Faraday observed that excess charge on a conductor resided only on the exterior and didn’t influence anything on the inside. He then built a room coated with metal foil and hit it with high-voltage discharges and used an electroscope to show no charges inside the room. This hank provides that similar design.
It's also not a "simple RFID device" but hey ho...
Smoke cloak, strobe light and a master blaster. Hooked up to the panic button on a spare fob, when activated the ignition will cut, doors will deadlock, cabin will fill with dense smoke paired with a strobe would disorient and the master blaster will make ears bleed.I think that approach might have a few drawbacks - it would wreck the car and potentially harm anyone who happened to be nearby, plus it would trigger terrorist alerts all the time and that would harm more people. Interior car guns to shoot everyone inside a lot? Many of the same problems. Poison gas? The thieves could open a window.
We need to get Q on the case!
Only one problem, if they p!$$ themselves you might have to torch the car.
I wasn’t being serious!or you have a minor accident/bump and inadvertently trigger parts of this DIY security system on your way to work...
