HI there
Kingston have given us some epic support to sell their Predator DDR4 at very low prices, the advantage of the Predator DDR4 kits is they run at very low latencies compared to other kits which helps improve performance:
Kingston Predator 16GB (4x4GB) DDR4 PC4-19200C12 2400MHz Quad Channel Kit - Black (HX424C12PB2K4/16) @ £155.99 inc VAT
Kingston Predator DDR4 is some of the most aggressive looking DDR4 available and looks menacing. Make your opponents fear you with Kingston Predator DDR4.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 12-13-13-35
- Tested Voltage: 1.20-1.35V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
- Warranty: Lifetime
Was [£179.99] Inc. VAT
Only £155.99 inc VAT.
ORDER NOW
Kingston Predator 16GB (4x4GB) DDR4 PC4-21300C13 2666MHz Quad Channel Kit - Black (HX426C13PB2K4/16) @ £191.99 inc VAT
Specification:-
- Tested Speed: DDR4-2666 MHz (PC4-21300)
- Tested Latency: 13-14-14-35
- Tested Voltage: 1.25-1.35V
- SPD Voltage: 1.2V
Was [£215.99] Inc. VAT
Only £191.99 inc VAT.
ORDER NOW
Kingston Predator 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit - Black (HX430C15PB2K4/16) @ £239.99 inc VAT
Specification:-
- Tested Speed: DDR4-3000 MHz (PC4-24000)
- Tested Latency: 15-16-16-36
- Tested Voltage: 1.25V-1.45V
- SPD Voltage: 1.2V
Was [£249.95] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
This is some seriously quick DDR4 and is far cheaper than our competitors are selling slower Corsair DDR4 kits for. Well worth jumping on!
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
Specification:-
- SPD Voltage: 1.2V
ORDER NOW
