Hi there
OK do not take this serious but I do find this personally rather amusing that Kingston seem to think you need two mouse mats, I am like mmmm OK, but hey maybe they are right, anyway check them out:
HyperX Skyn Mouse Pad (Control) @ £8.95 inc VAT
HyperX has the Skyn to win with two mouse pad textures available individually or in a dual pack. Choose the control surface for increased gaming accuracy or the speed surface for fast-moving action. Both are ideal for everyone from noobs to pros and feature ultra-thin, anti-microbial material designed to keep you winning for hours. HyperX Skyn works with optical, wireless or laser mice and sticks to most surfaces for high performance at home or on the road.
- Paper-thin, gaming-grade hard surface - more even and seamless transition between desktop and mouse pad, unlike traditional thicker mouse pads
- Material designed for prolonged use - anti-microbial surface to prevent dirt and bacterial build-up as seen in cloth surfaces
- Adhesive bottom with a pull-off tab - sticks to most surfaces and is easily removable
- Control surface for increased accuracyfor fast-moving action both compatible with optical, wireless or laser mice
- Guaranteed - 2-year warranty, free technical support
Specifications:-
- Product TypeMouse pad
- Package Content 1 mouse pad
- Product MaterialPlastic
- Width 35.5 cm
- Depth 25.5 cm
- Height 0.254 cm
- Weight 20 g
- Features: Anti-microbial finish, adhesive bottom
- Manufacturer Warranty 2 years
Only £8.95 inc VAT.
ORDER NOW
HyperX Skyn Mouse Pad (Speed) @ £9.95 inc VAT
- Speed surface for fast-moving action both compatible with optical, wireless or laser mice
Specifications:-
- Package Content 1 mouse pads
- Width 35.5 cm
- Depth 25.5 cm
- Height 0.254 cm
- Weight 20 g
Only £9.95 inc VAT.
ORDER NOW
HyperX Skyn Mouse Pad (Speed & Control) Multi Pack @ £19.99 inc VAT
- Two mouse pad surfaces - choose the Control surface for increased accuracy or the Speed surface for fast-moving action both compatible with optical, wireless or laser mice
Specifications:-
- Package Content 2 mouse pads
- Width 35.5 cm
- Depth 25.5 cm
- Height 0.254 cm
- Weight 20 g
Only £19.99 inc VAT.
ORDER NOW
Maybe Kingston are onto something with this idea, I have no idea, I personally feel they were maybe just smoking some illegal substances at the time they came up with this idea.
Specifications:-
- Width 35.5 cm
- Depth 25.5 cm
- Height 0.254 cm
- Weight 20 g
Only £8.95 inc VAT.
ORDER NOW
Specifications:-
- Width 35.5 cm
- Depth 25.5 cm
- Height 0.254 cm
- Weight 20 g
Only £9.95 inc VAT.
ORDER NOW
Specifications:-
- Width 35.5 cm
- Depth 25.5 cm
- Height 0.254 cm
- Weight 20 g
ORDER NOW
