Maybe not in a normal reflector enclosure but what about projectors?
It's normally the dodgy looking wiring and ballasts hanging out the back of headlamps that are stamped HCR rather than DCR that gives it away
yesI understood that there was a minimum lumen requirement for washers and a rare few cars with HIDs fell below this.
The pistonheads thread is interesting suggesting
legally LED>2000 lumens need washers/self-levelling (sealed units excepted) - is that because it is dirt that gives undesired beam deflection ?
Philips Ultinon aftermarket were not ce qualified sep17 - are there any aftermarket bulbs that are ?
The H4 comparison video shows how much light actually comes out despite these 6000/10000 lumens claims -lol
Ehhh.... what? Can you clarify exactly what you mean by this?No external lighting is allowed to be retrofitted.
Interesting. I wonder which cars they were? I remember when HIds first cam rout and I was super jealous of anyone whose car had them.
They cant be E marked so technically they cant be road legal. Though no one really cares.
Porsche Cayman is one example I found.
It would seem that on the standard boxster Porsche provide the Bi-Xenon lights in the UK as standard. But to save pennies, they have found a way of providing these lights with NO headlamp washer and that has resulted in a 25 watt arrangement to make them legal, as opposed to a 35 or even 55 watt package, as found in normal high wattage Bi-Xenon lights.
The net result is a low output and dim light. Its almost ok in dry conditions, but on wet and shiny roads, normal xenon lights just light up the road and these are completely lost
The bulbs are a DLS variety and no one makes an upgraded bulb yet !
There are plenty of E marked external lighting systems for cars?
No retrofit LED bulbs are. You would have to replace the whole unit for a proper LED one.
Regardless of that being true or not though, it's not checked at MOT, which is why you've never had any issues with LED bulbs at MOT - it's not because your tester doesn't care, it's because the MOT doesn't care.
Headlamps are the only place they're specifically mentioned and that only changed 2 days ago.
So your first post is fake news then?
But E marks apply to every external bulb. It should fail but it wont.
the instant on/off, of led, is a giveaway for headlights vs halogen at an MOT ? EDIT:and colourThey can't confirm it has LEDs though.
So not "No external lighting is allowed to be retrofitted" thenThey cant be E marked so technically they cant be road legal. Though no one really cares.
No retrofit LED bulbs are. You would have to replace the whole unit for a sealed LED one from a later model car etc.
It isn't difficult to spot an aftermarket HID install - and if one is spotted, it fails. It's that simple really.
