LED fans for Corsair H100i V2?
LHM
LHM
17 Dec 2015
Cheshire
I have the Corsair H100i V2 (240mm) fitted in the top of my Corsair 450D case. I want to replace the 2 stock radiator fans with white LED ones. Can anyone recommend which ones I need to go for to attach to the AIO cooler?
1 Mar 2010
you can used any 120mm fans from corsair just make sure they have PWM (4pins), so that you can control them via the software. Looking at another thread on here they have an aura version from corsair which only supports 3 pins (non pwm, in which you would have to connect to the motherboard to monitor the speed of each fan.
