LED has gone out on my Yate Loon. How can I fix it?
10 Dec 2006
Hi there,
I've noticed that one of my LED's on my Yate Loon's has gone out. How can I fix this?
(It's the top left LED on the bottom blue fan pictured).
Firstly I'd check its connections, easily done if you have a multi-meter. If thats whats wrong it may just be a case of soldering in a wire or two.
If it is the LED thats gone, then buy a new one from an electronics shop and replace it. The problem with this is it might not be quite the same blue as the others.
PK!
Two LEDs mine on a Yate Loon I had went out and I sent it back and it got replaced.
Got it from the same place. ;)
