Thanks for your mini review buddy.
Think this is the monitor for me tbh.
Not the best review but i give you a idea, if you do get one let me know what you think
did i read somewhere you need to use display port to get this running at 144hz or am i imagining things?
I have 2 running on Displayport and 1 off Dual DVi, my 7970's have 2 x mini displayports, 1 x HDMI and 1 x Dual DVi outputs, if I remember correctly it's the HDMi port that can't do over 60hz, the Dual DVi and displayports can do 144hz, which is working fine for me.
Got home and mine was waiting for me, i've set it up and testing it out now, first impressions are that the colours are a bit better than the Benq XL2420Z when looking at pictures, desktop and videos. I'm just checking out some games now to see how good the motion is.
Keep us updated, I've been looking on 144hz monitors for couple days now and thinking of that LG or Benq XL2430T or the Viewsonic VG2401mh. The LG from what you are ppl saying seems like the ebst deal, but Viewsonic has 8-bit panel
I see what you mean, surely there must be a way of saving this. Will check.
Edit, ok if you choose one of the FPS modes, then go into screen, then picture settings, you can choose and save it there, not sure why you can't do this in gamer modes.
I had mine all set at default but tonight I'm going to try fps with response time on low, see what happens, it looks awesome on Project cars @120hz on eyefinity.
Thanks for sharing, will try these at some point, there gors my 'low is better' theory lolThe manual says that high is the quickest response time. And low is the slowest.
So my settings so far.
Gamer 3
Auto brightness
70 contrast
50 red
50 green
46 blue
Gamma 2
(Found the 50/59/46 from prad.de tests)
Thanks for the response, yes I noticed that you can change the response time from the MENU > SCREEN > PICTURE > RESPONSE TIME while in the FPS1, FPS2 or RTS profiles.
But watch what happens when you go back to the GAMER1, GAMER2 or GAMER3 profiles. Select MENU > SCREEN > PICTURE, the response time is still set to MIDDLE and it cannot be changed from that setting. At leaset on my monitor anyway.
The reason why I prefer to use the monitor with the GAMER1, GAMER2 and GAMER3 profiles is because if you want to change the 'Black Stabilizer' setting, you can just press the 'BLACK STABILIZER button at the front of the monitor, and just change it.
If you are using the FPS1, FPS2 or RTS profiles, watch what happens when you press the 'BLACK STABILIZER' or 'DAS MODE' buttons, it will ask you to disable the game mode first before going any further.
So in other words, you can either use the GAMER1, GAMER2 or GAMER3 profiles without the best response time, or you can use the FPS1, FPS2 or RTS profiles with limited Black stabilizing function.
Check your monitor and see if it is the same for you.
They have those settings for the brightness at 17 but that seems rather low to me.Thanks for sharing, will try these at some point, there gors my 'low is better' theory lol
