Hi there
We requested when we first took this monitor that we felt it was poor it was offered with only a 2yr warranty for a monitor costing nearly £1000.
LG came back to me yesterday and confirmed that all the stock on 34UC97 which OcUK ordered from them has being upgraded to a 3yr warranty.
GOOD WORK LG!
Remember this monitor is part of our JANUARY SALE which ends today at 14:00 so bag yourself this great monitor and have the confidence it now comes with a 3yr warranty.
LG Flatron 34UC97-S 34" WideScreen Super-Wide Curved LED Monitor @ £779.99 inc VAT
21:9 Curved UltraWide QHD (3440*1440) display offers visual comfort with 2.4 times more visual information at one time than a Full HD monitor. And also, the QHD resolution’s 1440p vertical height allows you to use more vertically than a 29 inch 21:9 monitor.
IPS’s 178’ wide viewing angles, close to 180’, allow you to view the screen clearly without distortion. Also, the Curved IPS provides an immersive viewing angle covering the entire viewing angle around your range of vision.
You are guaranteed an immersive artwork by perceiving the same color as a subject on display or print through a sRGB over 99% colourspace and IPS’s accurate colour expression.
34UC97 provides two Thunderbolt2 ™ ports to directly connect a Mac PC and Pegasus2 storage directly to transmit data more than four times faster, than a USB 3.0. As a result, there is no concern of slow transmission from using a USB or HDMI connection. You can connect to various devices with the two HDMI and two USB 3.0 ports, and a Display Port. And, If you have a Mac, you can connect directly to the 34UC97 via Thunderbolt 2™, which transmits data more than four times faster than USB 3.0.
Using MaxxAudio® technology you will experience deeper bass and crystal clear highs. Equipped with two 7w internal speakers and MaxxAudio® technology, the 34UC97 provides cinema surround- like sound, allowing you to enjoy movies without any extra external speaker or sound output equipment.
Specification:-
- Screen Size Class (diagonal): 34" Curved
- Panel Type: IPS
- Aspect Ratio: 21:9
- Resolution: 3440x1440
- Color Gamut (CIE1931): sRGB 99%
- Brightness (typical): 300 cd/m2
- Contrast Ratio(Original): 1000:1
- Response Time: 5ms
- Viewing Angle (CR>10): 178/178
- Colour Depth (Num of Colours): 1.07B (8-Bit+FRC)
- Pixel Pitch (mm): 0.2325
- Surface Treatment: Anti-Glare 3H
- Curve: 3800R
- Connectivity: 2x HDMI, 1x DisplayPort & 2x ThunderBolt
- Speakers: 2x 5W
- Tilt: -5 / +15
- Set with stand: 830.5 x 224.5 x 472.9
- Set without stand: 830.5 x 106.4 x 370.3
- Weight: 8.2kg
- Linus Review: https://www.youtube.com/watch?v=RWgQmpzdqpc
- Warranty: 3yr (LG On-Site)
Was [£989.99] Inc. VAT
Only £779.99 inc VAT.
ORDER NOW
GOOD WORK LG!
Specification:-
- Panel Type: IPS
- Curve: 3800R
- Speakers: 2x 5W
- Tilt: -5 / +15
- Weight: 8.2kg
ORDER NOW
